Question about ViewSonic VX924 19" LCD Monitor
My lCD binks slightly you can see the display(dim).
I open the inside and the power module has a dark brown on part (1/2 ) from the rest of the board. Can it be the power bd? and where do you buy it? Does it cost alot?
thanks,
wm ortiz
wortiz@hot.rr.com
  • 45 Answers
Hmm,
well you dont open the Monitor for these because it usually Voids the warranty.
and as far as Parts for the Monitor are concerned they will not be available seperately.
you will have to service/Replace the Monitor.
Posted on Jul 17, 2008
Very dim display..so dark that all I see is a faint picture. Are bad capacitors to blame?
I would say either the video cable has disconneted, causeing the led that lights the screen up to not function,, simpley take the bezel around the screen, take the small screws aroud the screen to slightley pull the screen away from the back top to see if the cable is, or has pulled loose...If now the screen is bad..
Oct 13, 2014 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
The screen goes dark. When U cycle the power switch off then on again the screen display returns for about 1 second then goes dark again. I would appreciate suggestions on what to do.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
LED POWER ONLY LIFE, SCREEN DISPLAY DARKNESS
theres only one solution to the problem you have to replace the whole power supply board .its easier to replace them than finding and soldiering the defective parts like the capacitor on the board .u can just replace the power supply board if u think the power has a problem. if it doesnt work then u have to replace also the main board or the board connecting the rgb cable.its more expensive to replace the board but its worth it. ur lcd will work better and its easy to put them on the lcd casing .
Mar 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Acer AL1512 LCD Monitor Problem
Based on your description, the problem could either be:
  • CCF (cold cathode florescent) lamp; and/or
  • inverter.
Since the Acer AL1512 works fine except dark, we can rule out the video interface, power supply and ontroller. Again, the display showing (even dimly) is significant, it tells us that the components are working except that for some reason and most likely it is heat related. Possibly a cold solder, a loose connection and/or a dried up capacitor. You could actually verify this be shining a flashlight diagonally across the screen and some semblance of the desktop albeit dark would be slightly visible.
What is required is opening the LCD lid/panel to perform repairs. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 23, 2008 | Acer AL1512 15" LCD Monitor
Faulty hp en623aa flat screen monitor
my desk top is half display is ok and half display is white light & all program is look a lite
Jul 24, 2008 | Xerox XG-91D 19" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
BenQ FP72G 17" LCD Monitor NO DISPLAY
Check the ribbon from the video card to the back of the panel. It has to be aligned perfectly and locked down in the right position at the video card side, and pushed in corrctly to the panel.
The section that contains the inverter circuit is totally seperate from the rest of the power supply. Seperated by the fuse link marked FBxxx.
Apr 22, 2008 | BenQ FP72G+ 17" LCD Monitor
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
Top ViewSonic Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer Monitor Expert? Answer questions, earn points and help others
