Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Pink vertical line in middle of screen.
I have a reddish pink line that runs vertically on my screen. It is present on every channel and when the cable is not plugged in. Can anyone help me figure out what is going on? I just replaced the convergence board (picture is great) so I know this is not the problem.
Rob
  • 1 more comment
  • jbourque Jun 29, 2008
    Me too! I just put in new IC chips in the board. My color is good now but I have this pink line running down the center of the screen.
  • Mr Michael Aug 27, 2008
    I have the same problem. Anyone have a clue how to fix this?
  • dlane321 Dec 12, 2008
    'This is my Mom's television just been repaired recently and it has the same problem. Can some one out there provide the solution for it.
    Dennis
Its got pink shadows round the picture
Posted on Jun 22, 2008
Screen pink vertical lines
Probably the tft screen, this can be easily tested by plugging an external screen in. If they both give the same issue, you have a GPU issue.
Dec 14, 2013 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
I have a 22" Samsung
This will require a service center to fix. The pink line gets caused by the control board when it fails. If it is under warranty contact Samsung.
Mar 02, 2011 | Samsung LN52A850 52 in. LCD HDTV
The color on my Samsung Slim Fit TV suddenly blipped to pink and blue. When I turn it off and back on, it comes on with a green line across the middle of the screen. What's up?
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Feb 08, 2011 | Samsung SlimFit TX-T2782 HDTV
There is a black line and see through pink bar on my monitor
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warenty its usually 3 years
Apr 12, 2010 | Dell 1702FP UltraSharp 17" TFT LCD...
Multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
50. In LCD samsung has pink vertical lines
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Mar 03, 2010 | Samsung LN-T4665F 46 in. LCD Television
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Pink vertical line on the screan
Hello pse try to connect an ordinary screen to your computer and see if you have the same problem then...use both screens at the same time ...and see if your lcd is the same or not...please tell me how it went...good luck...be hearing from you...Ron
Feb 27, 2008 | Compaq Presario M2000 Notebook
What are these lines?
This is a LCD projector, one of your LCD Panels is blown, This is a $400 repair.
Jan 22, 2008 | Hitachi CP-X980 Multimedia Projector
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
469 people viewed this question
Henry  Thomas
Henry Thomas
