A msg OSD Locked is always blink on screen of my TFT Whenever i press any switch(Menu or Autoselect)it shows the msg OSD Locked A msg OSD Locked is always blink on screen of my TFT Whenever i press any switch(Menu or Autoselect)it shows the msg OSD Locked
-   hello my friend,i am also frusted to osd locked in my computer.when i open computer then that time computer will start but after sometime automatic computer screen is off. but cpu will be run , only LCD moniter screen is off.
when i again ON my LCD screen then LCD monitor on but osd locked massage shows.-   sarvesh idea
Sep 10, 2008
-   I have a 17"inch HCL LCD monitor. when i open my computer shows OSD locked in each time.our screen is open that time but after some time our screen is automatically closed .we again open our computer by LCD monitor on/off switch.
-   sarvesh123
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you
dismantle the casing, which voids any warranty.. so, if the monitor's
still covered by the warranty, or if money is not an issue, have it
repaired by professionals on an accredited brand shop (check your
warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on
the circuit board, and try to release it using something thin like a
screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop,
sending a continuous signal to the board (which keeps locking/unlocking
the OSD).
If so, your only solution (other than take it to a repair shop) is to
remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is
better than to have a message stuck on front of your screen all the
time..
This is a tried and working solution, since I had this problem myself
(with a Philips 190B monitor), and solved it successfully, with this
method.
I have a LG Flatron W2043T monitor that wont turn on, just says analog power saving mode. Can you...
(More)
I have a LG Flatron W2043T monitor that wont turn on, just says analog power saving mode. Can you help?
when i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop,...
(More)
when i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop, power supply fan also turn few times and stop and computer does not start.
my 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this...
(More)
my 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this monitor ? how can i fix this ?? ive confirmed 120v at power inlet and some dc voltage on various mini pins on digital plug going into monitor
