Question about Kenmore 45081 Front Load Washer / Dryer
Kenmore Elite HE4t Washer
It wont drain or spin. It gives me a error F 02, there is nothing stuck under the rubber of the door. I checked the hose it is clear, the wall drain is clear and it is between 30" and 96" from the botttom of the washer as Manuf. suggests. It turns off every minute and I have to press "cancel" then "start" and it runs for another minute then gives the F 02 again. It also throws a few "suds" error codes and adds water, and the nightmare starts over!! I use only HE detergent and have even tried running cyles with no detergent, in case there was a build up. I have a husband and 2 teenage boys....I need to wash clothes. Any suggeastions? I have a problem with my kenmore he4 45081. It wont drain or spin. It gives me a error F, there is nothing stuck under the rubber of the door. It turns off every minute and when I press "cancel" then "start" and it runs for another minute then gives the F again. It also throws a few "suds" error codes and adds water. Please let me knwo what could I do to fix it?
  • 4tomanykids Jul 06, 2008
    My Kenmore Elite 4t washer keeps displaying the F02 Error code. I have checked under the rubber ring and removed a sock that was stuck, but that didn't help. We used a wet-vac to try to **** out the hoses, but that hasn't helped either. I have to constantly push pause and then start to get through one load. It has taken me literally 7 hours to get through one load of clothes. I don't overload the machine and only use HE detergent.
  • marysfoodhav Jan 27, 2009
    Kenmore HE3T Front Loader.... I HATE THIS WASHER... KENMORE HE3T... HATE IT HATE IT....
    Will NEVER BUY ANYTHING like this again... you would think Sears is the better companies out there but I had nothing but problems since DAY one. Three boys and a laundry machine that constantly gives error messages and takes all day to do one load.... ARGHHHHH!!!!
    So I did remove the bottom panel... emptied out the water... took only a piece of plastic from the hose which was small enough... Checked to make sure all wires are connected.... STILL same problem F O2 and sometimes SUD error.... Do I have to take the whole d*mn machine apart??? HELP
    Genius:
  • 1,028 Answers
Remove bottom panel pump is slightly right of center in white housing the is a knob turn counter clockwise ckd for anything that may be blocking pump or has pump impeller locked be sure to ck as far as possible into pump throat if impeller is locked pump can be removed and taken apart just remove hoses and power plug take pump completely out and remove screws around edge reverse procedure when reinstalling just be sure large o ring is reinstalled properly
Posted on Jun 10, 2008
It will not strat and it bebe
Posted on Oct 08, 2008
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Kenmore Elite HE4t Washer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Posted on Sep 12, 2007
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Oct 24, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite HE4T Washer
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2009 | Kenmore Washing Machines
Stops washing cycle without draining and spinning: gives error code F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Apr 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
Kenmore He4t frontloading machine flashing F 02
U have something stuck in your water pump u need a torx 20 and some hose clamps unplug the machine take the three torx screws off the toe panel put the hose clamps on the white plastic waterpumps hose that goes from the back of the pump to the bottom of the drum unscrew the pump to the left and pull out you can also use the toe panel to catch some of the water pull anthing out of it that u can and replace everything back try taht first
Mar 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 45081 Front Load Washer / Dryer Logo
400 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
