Question about E-Machines T2240 PC Desktop
Tried to turn it on, no powr. Replaced the power supply, little led on the mother board, but no power, no fans.
What do I do now?
I turned on the PC.
No power, no fans.
I replaced the Power Supply, still nothing.
Little led on the board lights.
No fans.
What now?
Steve
No good.
Did all that.
Junk
Posted on Jun 12, 2008
  • 100 Answers
* check wheather wall plug is fine or not if not change it
* check motherboard wheather ram,vga card,microprocessor is fixed properly then restart
No beeps.
I tried 3 different power supplies.
I stripped out the memory and hard drive and put it in the dumpster where it belonged.
Steve
Posted on Jun 11, 2008
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Gateway Desktop GM5626: Would not power-up, replaced Power Supply; Then Mother Board beep once when trying to turn-on; replaced Mother Board; Mother Board lights on, but when I try to turn on the CPU...
some powersuplay comes with 2 extra connectors a 4pin based switch connector and a alternate power supply for the fan...you must to be sure if it is comatible......check the model and search on google for compatibility ...
May 31, 2011 | Computers & Internet
My e-machine will not turn on....I have put in a new power source, tried a different turn on switch, the power light on the mother board comes on but its as if it is just plain dead...no fans run when youi...
My sister had the same issue with hers. She said one day it died. I replaced the power supply, the little lights on the mobo came on, but the computer did not power up. Come to find out, when the "best-tec" power supply fried, it surged the motherboard and fried that as well. I replaced the motherboard and it works like a charm.
Feb 15, 2010 | E-Machines eMachines Desktop PC
Intel 210882 mother board power won't spool up fans or anything.
usually power supplies comes in different voltage n wattage . check ur mother board manual that which type of powre supply it support than replace it with the good one.it may solve ur problem.thanks
Apr 17, 2009 | Intel Motherboard
No display on monitor
Check your RAM card and Video adapter .Because problem of one of that thing computer wont on the monitor video.
Jan 10, 2009 | Intel Desktop Board D845EPI Motherboard
Pc will not power up
Swimmie
to chack ur power supply open all connector from system board and drive. then conect power cable with powr supply and powr on ur wall outlet switch. than take mother board connector find green color wire and take a small pice of coper wire and connect it with this green wire and a black wire. then chack smps fan is moveing or not if it's moveing then ur smps OK.
Jun 27, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
E-Machines T2240 PC Desktop Logo
90 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
