Printing faded color text on my color paper...
Im trying to print color text on heavy stock (215 g/m2) color paper (yellow) on a Konica Minolta bizhub c203 color copier, but when ever i do, the color looks faded. When I print on other paper type, it comes out clean. What am I doing wrong? and is there a way to change setting so that I can print on that color paper and paper type?
thank you
TerryYaki
  • 1 more comment
  • TerryYaki Jun 09, 2008
    I did try both, through the tray and the bypass and I get the same result, the paper goes thru fine but the quality ends up the same.
    sorry about that, it says, 80lb (215 g/m2) - Cover - 215 sheets -
    8 1/2 x 11 - 28.77 M - smooth finish (not glossy) and its yellow paper (Astro Yellow)
    Yes, I was reading the manual and your right, thank you for all your help and thank you for the quick responses, i appreciate it.
    thanks once again
  • 2,794 Answers
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Posted on Jun 09, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jun 09, 2008
    Is the paper glossy?
    It would help if you can tell me what the label on the paper stock says.
  • Tim Babcock
    According to the owners manual that paper is out of spec. The maximum weight you can use on a Bizhub is 72 lbs on the bypass tray.
    Anything heavier than that can cause scratching to the drums, copy quality issues, as well as jamming.
  • Tim Babcock
    You are welcome.
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Konika minolta 2400 color laser printer : Paper jammed and stuck
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2530DL
Open the top cover of the printer and remove the drum (piece with long green handle). Look down inside the printer and you will see a roller with ridges. Clean that roller with formula 409. Try not to use alcohol because it dries the roller.
If you are printing on paper thicker than 23lb. bond, you want to make sure you select "thick stock" for the media type on your computer.
For instance... in your application click on file and then print. In the print window select properties (usually). On the setup tab of the next window you will see media type on the right side. Set it to the type of paper you are printing on. This should make the printer pick up the paper slower.
If the paper is thicker than 90lb index (160 g/m2) it is too thick to go through the machine.
May 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Problem with the printer drum?
Sounds like the toner isn't sticking to the paper.
Open the top cover of the printer. You will see two yellow felt stickers with a black triangle on them. On either side of those stickers you will see two gray or green tabs. If the tabs are sitting up pull them down towards you so you can see the picture of the envelope on top. Close the cover and try to print.
Mar 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
294 people viewed this question
jasbo
jasbo
