Question about Acer Aspire 5050-3242 Notebook
Wireless connection I am having an ongoing problem connecting to an staying connected to by home wireless network, the button on the from does not allow wireless to be enabled? Help
Download software wireless??
i dont know..please help me...
Posted on Jul 18, 2008
    Novelist:
    Champion:
  • 210 Answers
Click on start>control panel>network and internet connections>network connections, now right click on the wireless adapter and select "Enable" at the top.
The button on the front will not work correctly if this is not enabled, if your problem persists after this then follow this.....go to start>control panel>performance and maintenance>system>hardware tab>device manager, now look down the list of devices and click on the +/expand option next to "Network Adapters", now right click on the wireless network adapter and uninstall it, now reboot the laptop - When you boot to windows it will automatically pick up the wireless adapter back up and install the drivers for it.
You may need to put in you wep
Posted on Jun 14, 2008
  • xCAUSALITYx
    xCAUSALITYx Jun 14, 2008
    Sorry pressed enter and it submitted the post.......continued
    You may need to put in your WEP key in again.
    Let me know how you get on....!
    Please rate my solution when possible....!
    Good Luck....!
    Cheers
Cant connect wirelessly as i cant locate AOSS button
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your ps3 using it.
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
1)To use this set up for the PS3 go to Settings>Network Settings> Internet Connection Setting> (Method) Custom> (Select Connection Method) Wireless- (WLAN2_bing.gif Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
Again this only works if your router has this button. and it is not found on your ps3
so you'll need to set it up differently. if your home is set up with wireless router and your computers are connected online wirelessly read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
May 18, 2010 | Sony Playstation 3 (PS3) Console
Troubleshooting wireless home network using windows xp
To Configure a Wireless Connection in Windows XP, Follow the Instructions Outlined Below.
  1. Click the Start button, click Network Connections, and choose Show all Connctions.
  2. Click the Wireless Network Connection icon with your right mouse button, then choose View Available Wireless Networks.
  3. Choose the name of the 2Wire access point from the Available networks list.
  4. In the Network key field, type the hexadecimal key to access the wireless network.
    Note: The hexadecimal key and wireless network name should already be set up on the 2Wire device. Use the key that you set up on the 2Wire device.
  5. In the Confirm network key field, type the hexadecimal key to access the wireless network again for confirmation.
  6. Click the Connect button.
Apr 15, 2010 | HP Pavilion m7680n PC Desktop
My wireless button doesn't work right for wireless. It wants to stay in wire hookup mode?
What is it you are trying to do?
Just pushing a button does not connect you to a wireless network--it simply turns on the wireless capability (enables your wireless network connector). You then have to actually connect to the wireless network of your choice by entering your username and password. How you connect depends on your computer. If you are using Windows to manage the connection, you simply click on the little icon in the system tray and tell it to show the available networks and choose which one you want. If you are using a utility provided by the computer or network card manufacturer, you must use that to connect.
Oh, and you need to disconnect the wired connection. You may benefit from restarting your computer to allow the network to re-establish a connection.
Jan 06, 2010 | Compaq Computers & Internet
IPod Touch does not connect to my home network?
In my case, I keep getting endlessly prompted to enter my passcode for my wireless router. I found that if I reboot the iTouch - hold down the top power button and slide the "slide to power off". Wait for it to finish powering off and then power it back on by holding the same button. When it comes back up it automatically connects to my home network again. Seems to happen every time I connect to an outside wifi network and then return home... I wish I knew WHY it does this - I suspect it has something to do with how my home wireless router is configured.
Dec 22, 2009 | Apple iPod touch
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless Adaptor Issue
First make sure that your wireless router is set to broadcast (or if you prefer not to broadcast) your SSID (your wireless network name) or that your laptop wireless network connection properties is set-up to "Connect even if this network is not broadcasting".
To check this go to:
Click Start> Connect to>Show all connections>
Right click your Wireless Connection and select properties>
On the Properties box select "Wireless Network" tab >
Go to "Preferred networks" then highlight your SSID (network name)
Click "properties" button check "connect even if this network is not broadcasting". (while youre here check that your "Wireless network key" confgurations are correct).
Make sure that you are also set-up to "Obtain an IP Address automatically " and "Obtain DNS server address automatically"
To check:
Select "General" and under the heading "This connection uses the following items">
Highlight "Internet Protocol (TCP/IP) then click "Properties" button
Jan 10, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
No internet connection with laptop computers in home
Good day!
If your Desktop computer is hardwired to the router and your laptop computers can't connect wirelessly, it could be your wireless computers are not synchronized with your router by not having the same settings as the router.
You can use the desktop machine to access your router web interface (setup page) to check the wireless settings such as SSID (Network Name-> Name of your wireless signal shown on your laptop computers), channel and security (wether it is WEP or WPA encryption)
The channel and network name will be automatically detected by the wireless computers. If you have an encryption/security on the router, you need to type the password on the wireless computers for them to authenticate.
Try these and post back if there's any progress
Aug 03, 2008 | NetGear : WGT624 108 Mbps Wireless...
Lost wireless connection
Do one thing right clik on my computer and choose manage option after that services in that service
in that wireless zero configuretion will start after then go for the right clik on my network place in that propertities
wireless network icon in that right clik and properties .tcp/ip protocol clik and properties
give the obtain automatically.
May 25, 2008 | Computers & Internet
My psp
First, you must be in range of a Wifi hotspot (wireless local area network). You can adjust network setting to connect to an access point such as a Wi-Fi hotspot or the router on a wireless home network and save the network connections data on your PSP. Up to 10 connections can be saved.
Hotspots can be found in airports, hotels, restaurants, and at home if you have a wireless network. Once in range of the hotspot, go to "Settings" menu, >> "Network" Settings and press "X" Button. Select "Infrastructure Mode" and press X Button. Set up the "New Connection". For details about Infrastructure Mode set up, or Ad Hoc Mode set up, visit us.playstation.com.
Search for networks in range. You will usually need a signal of at least 40% to connect - the higher the percent, the connection will be faster. If the connection is successful, information about the network connection will appear. hope this helps.
Nov 20, 2007 | Sony PlayStation Portable (PSP) Console
Acer Aspire 5050-3242 Notebook Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
