Question about Samsung Refrigerators
I have a frigde and the problem iwth it is,the temperature is too high and the frigde is not cold it has started to have a bad smell
  • 958 Answers
Your compressor is not running.
Posted on Jun 09, 2008
My 2003 BMW X5 3.0i is stalling out, engine runs erratically, lots of smell and smoke from underneath the back of the vehicle. Is this a bad Transfer case?
Computer is in constant cold start mode, dumping too much fuel into the engine, because of a faulty temperature sending unit. Has nothing to do with the transfer case for AWD. Replace the temperature sending unit and all will be well. All computer can do is what it's told, and it's being told the engine is not warm yet and keeping it in cold start mode.
Dec 10, 2012 | BMW X5 Cars & Trucks
Engine turns but won't start when temperature id around freezing or below.
Possible bad cold start valve or the sensor that tells the valve to activate when cold. Start by replacing the cold start valve first.
Sep 17, 2012 | 1990 Dodge Caravan
Frigde temperature high.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jul 06, 2011 | Samsung RS2630WW Side by Side Refrigerator
Refrigerator section not cold. Light is on inside the refrigerator but temperature is not working. Freezer bottom is functioning. Purchased the frigde less then a year.
I would start by checking to see if the evaporator fanis running . It moves the cold air from the freezer up into the refrigerator compartment
Jun 22, 2011 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
My fridge/freezer defrost itself last night and the freezing and frigde temperatures went low and my frozen food was all thawed
manually rotate your defrost timer maybe it stuck up and the contact was on the defrost heater. adjust your thermostat setting to coldness then observe unit.
Mar 05, 2011 | Refrigerators
I have a small GE refridgerator and last night while chipping ice out of the small freezer it has, i punctured a small hole that had a plasic cap on top of it. It started leaking some kind of colored fluid...
you have peirced the main gass line thus releasing all the gas from your fridge it wont get cold having it sealed and re gassed cost more than a new frige time to get a new frigde /sorry/
Apr 21, 2010 | Refrigerators
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Hard starting when cold, smelly exhaust
Car exhaust starts to smell bad (like rotten eggs) because of the sulfur content in the fuel and the catalytic converter not functioning properly. This can be a dangerous situation if the cat goes bad or gets clogged because they do operate at a very high temperature and if clogged can cause a fire. Run the car for awhile and look at the cat. If it is glowing red, turn the car off immediately (It's clogged), and don't drive it until the cat is changed out. Source(s):
Mar 18, 2010 | 2002 Jeep Grand Cherokee
1994 corvette starts good if sits for 2 days but when warm, have to crank it to start and then a lot of gass smell...kind of bucks and some times backfires until warmed up
Coolant temperature sensor is bad. Telling computer that the engine is still cold and over fueling as if it were a cold engine.
Aug 24, 2009 | 1994 Chevrolet Corvette
Rich fuel smell in & out of car, causes my eyes to burn.
You changed everything but the temperature sending unit/sensor. That's what is your problem as far as no proper cold start. When first started and cold, the sensor tells the computer to place the engine into cold start mode, engine starts and runs because it's at a bit higher idle and getting a bit more fuel. When warmed up, the sensor, if good, will tell the computer to place the engine into normal run mode now. Have the sensor tested first. If good, the engine is not going into a higher idle and is still getting the fuel but not using it fast enough because it's flooding. Hence the fuel smell. That's the fast idle solenoid on the EFI for this and the A/C high idle when it's running.
Jan 06, 2018 | 2003 Kia Spectra
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
