Question about Toshiba 50HX81 50" Rear Projection Television
Toshiba 50HX81 I read some of your posts and see you offer great advice. Can you help us on this problem? Purchased TV, 6 1/2 yrs ago and recently right and left sides of screen show double vision. Perfomed the 9 point convergence manual adjustment but the lines do not come together on left and right sides, right side is far worse but the center was fine. The red and blue crosses are apart and cannot be aligned. From your responses to others I see it may the convergence IC's need to be replaced. Because this is a DIY fix, can the board with the IC's be replaced entirely so that soldering can be eliminated? Also, this heavy monster sits on a counter, can this replacement of the IC board be done from the front? Thanks for your time and advice.
  • Toshiba Master
  • 8,617 Answers
Yes the convergence ICs need replacing. I am not sure if your board is still available, however you may want to check the following link, they offer a service where they replace the ICs and convergence resistors often for less than most shops come out and diagnose for. Heres the link leave them an email with your model number and they will let you know the cost for repairing yours or wether a new board is available.
http://servicemanuals.vstore.ca/
Posted on Jun 11, 2008
Information on seeting convergence for 50hx81 tv
In the customer menu select convergence with the Toshiba remote.
If it is skewed and or will not adjust you have a convergence circuit problem. If this is the case let me know and I will tell you what is involved to repair the set.
I have fixed hundreds of sets with this kind of trouble.
If this has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 24, 2009 | Televison & Video
3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
Jul 25, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Looking for owners manual for toshiba 36''
hello there i have the link here for this manual here it is dont forget to leave rating if you found this info usefull thanks
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/27_32_36A50_A.pdf
Jan 25, 2009 | Toshiba 36A50 36" TV
Toshiba 50hx81 no picture or sound
If you managed to find a manual or have resolved the problem, please post it back here to benefit others. You probably had a partial or complete power supply failure.
Thanks-
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Mar 30, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hx81 power light just blinks
Go to Powered Products List view all in my profile and read
Toshiba entries........Let me know how it is going.........T.
Mar 15, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hx81 Squiglly Lines
Bad hyper board = Needs rebuilt, technician skill level high....
Sep 15, 2007 | Toshiba 50HX81 50" Rear Projection...
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
