I bought DVDR 3506/37. No set up menu when turned on. Wonderful picture but remote will only give me E-1, E-2, E-3, or 125. Wont do anything else except got hdv or tv. CAnnot access menu.
I returned the DVDR to the store and got a refund.
Posted on Jun 10, 2008
Bought 40" TV was floor
Try going to Remotes.com they have original remotes for all major brands.
May 09, 2011 | Toshiba Televison & Video
I have a dpx 4250 plasma tv with no remote and
Yea on set will be buttons, menu, up, down, enter/set using these buttons you can do anything you could on remote
Mar 18, 2010 | Televison & Video
I have a iLO DVD recorder,it will turn on and show menu on front of unit but I can't get the menu to come on screen of TV.It is model #DVDR05/ZU.. You put a DVD into unit and push play on remote and it...
I have a DVDRo4 model so they may not be the same. I connect 3 wire RCA cables to the DVDR output and to TV 3wire RCA input. I set the TV chan to Aux. I set the DVDR souce button to disc. Hope this works on you unit 05
Nov 22, 2009 | iLO DVDR05 DVD Recorder
New Samsung TV and home theatre kit
on the receiver thier is a swicth it is iether set to amp or tv/amp, amp will set it so you have suround sound, but you'll not have sound out of tv and you'll want it that way. the other with tv/amp will give you both. hope this helps
Sep 06, 2008 | Audio Players & Recorders
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Hi guys, don't know if the previous post got through. Have a new LCD tv and DVDr, connected with a HDMI cable. when DVDr switched off analogue and digital picture is fine. as soon as dvd is switched on...
yes, hdmi will give you better results..
are you running hdmi to hdmi connection on tv from cable box?
if so, that is correct but as for the dvdr, what tv port are you connecting it to? i would use another hdmi cable for the dvd too for best picture resultif it's an option on your dvd.. you should have multiple input outlets on your lcd with 1-3 options for input devices via analog or hdmi.. so analog is not hdmi--hdmi is digital so it switches to the hdmi resolution when you turn it on..
let me know how it goes and if i was helpful involving resolution.. helpful feedback is appreciated.. thanks, d
your dvd player should be set to a different
Feb 27, 2008 | Televison & Video
No picture no sound nothing
looks like a power supply unit (PSU) issue. You can not do anything about it. I suggest you contact the service center of your supplier.
Feb 11, 2008 | Televison & Video
ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Jan 27, 2008 | ESA ET413E 13" TV
Trying to hook-up new Philips DVDR3575H
Have you solved the problem. I am having the same issue.
Dec 16, 2007 | Zenith Z32X31D 32" TV
Sound but no picture
Apparently your TV doesn't support the progressive mode (480p). You should be able to turn it off by pressing the pause button on the recorder for about 5 seconds, untill it turns off I guess. Hope it works
Jun 13, 2006 | Sony RDR-GX315 DVD Recorder
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
