Question about Nesa Vision NSC-250 10.4'' Overhead Monitor
Brightness the screen will flash bright when I turn it on, but it goes dim after a couple of seconds. In daylight i can hardly see the screen, but it is completely dark at night or in darkness. I tried to adjust the brightness and other settings, but nothing as changed. thank you for any assistance
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Apr 08, 2011 | Hitachi Televison & Video
Disply screen has very little brightness
It could be a couple of things. The first is that screen brightness automatically dims when you go on battery, which is to save power. The second is that the brightness setting got changed inadvertently.
There are two function keys at the top of your keyboard that control screen brightness...one turns it up, the other down (they generally have a small circle with rays coming out...one circle is empty, the other filled...sort of like a sun and a dark sun). Hold down the Fn key and press one or the other of those function keys and see if that makes a difference in your screen brightness.
If that doesn't help, you may have a faulty LCD screen.
Hope that's helpful.
Jan 20, 2011 | HP Pavilion zd8000 Notebook
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
Sep 04, 2009 | Dell InspironTM 1501 Notebook
K 510i not booting
You have to flash your firmware. This can be done in a Sony Ericsson service center. However you can also do this manually from your PC.
Probably you experience this problem because your phone has damaged GDFS.
Jul 15, 2009 | Sony Ericsson K550i Cellular Phone
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
Car Audio & Video Logo
24 people viewed this question
Top Nesa Vision Car Audio & Video Experts
jdtech
ray gallant
Are you a Nesa Vision Car Audio and Video Expert? Answer questions, earn points and help others
