Question about Sony TC-WE475 Single Cassette Deck
Dule cassette dubbing
How do I dub tape to tape?
  • 38 Answers
No sir,
you can not dub a tape on single cassette deck, unless you have another cassette deck.
ramesh22
Posted on Jun 09, 2008
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
What are the steps to dubbing off the other tape?
You need a set of RCA AV dubbing cables (available at fine electronics stores everywhere), and a couple VCRs. Plug the cables into the "A/V Out" jacks on the back of the VCR that will be playing, and into the "A/V In" jacks on the VCR that will record.
Also on the recording VCR, use a regular coaxial cable to attach it to a television.
Now, set the TV to 3, fire up the VCR's, and set the recording VCR's TV/VCR toggle to VCR. Also on the one that is recording, set the channel to "INPUT" or "AUX" or something like that. (You're telling it to record what it sees coming from the jacks you plugged the cables into.) Then hit Play on the other machine. You should be able to see your tape playing back. If you do, you have followed these directions correctly, and you're ready to make your dub.
HINT: The first few feet of tape are often prone to dropout and generally sucking. Record a minute of black before making your dub. Mark this on the tape or tell them when you turn it in. They will be impressed.
May 28, 2010 | Sony DTC-ZE700 Dual Cassette Deck
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Going back and forth from recording to dubbing tapes
If there is a switch (either a mechanical switch or a relay) that changes the recording mode (something like normal/dub or record/dub), it might have oxydized contacts and this may be the cause of the problem. Cleaning the contacts inside the switch/relay or replacing the switch/relay will probably solve this.
You may want to check the switch prior to removing it. You can do it with a continuity tester (possibly with the kind that gives a sound signal when the continuity is good).
Otherwise, if the switch can be disassembled in a simple way, see if the contacts inside the switch are brownish/oxydized, if so, you need to clean them, but you also need to clean the clips that connect the contacts. Some fine sandpaper will do the trick, but be careful when you disassemble and reassemble the switch, some parts can easily get damaged.
regards
3rq8 (Triarcuate)
Nov 18, 2008 | Tascam 322 Advanced Dual Well Single...
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Aug 15, 2008 | Sony TC-WE305 Single Cassette Deck
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Teac w 600 r tape deck
PUSH DUB BUTTON HIGH SPEED OR NORMAL
Aug 14, 2007 | Teac W-600R Single Cassette Deck
Sony TC-WE475 Single Cassette Deck Logo
253 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
