Question about Maytag Dependable Care LAT9416
Burning Smell when spinning
Our Maytag LAT9416 has given us no problems for 8 yrs. This morning during the spin cycle, it sounded weak and I started to smell something burning. Could it be the drive motor? Any suggestions? Don't know whether it's worth getting fixed.
  • luftprop Oct 09, 2008
    Washer was stored for 2 years in a outside shed. Finally decided to use the washer and worked fine for 3 washes; next wash I smelled burning of some sort and spin cycle doesn't work nor does anyother cycle. I took the front panel off and noticed a most likely "mouse nest" with parts of fabrics in the motor area. Do you think the cause the motor to fail and if so, what's the easiest way to check the motor to see if it's any good? Thanks Bob First time here, can you also send a email to luftprop@centurytel.net
  • 413 Answers
8 yrs old....The LATs were the best models for Maytag...Maybe it's time to replace the belt..Slipping belts smell bad.
Posted on Jun 10, 2008
Maytag burning smell
sounds like you may have a motor belt slipping,unplug your machine and carefully tip it back, you should be able to access the motor and make adjustments from here
Oct 07, 2012 | Audio Players & Recorders
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
I have a maytag washing machine model A712, during the spin cycle there was loud screeching noises and burning smell. What could be the problem.
problem could be the gearcase or the motor, to find out remove the motor and turn it with your hands to hear any abnormal sounds coming out, and also try to smell the motor see if it has a burning smell
Oct 16, 2011 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Spin cycle won't spin. Burning smell. How do I
Remove the back -- you'll see the screws to do this. Sounds like the belt or the clutch is slipping and overheating.
Charlie
Aug 25, 2009 | Washing Machines
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
428 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
