TOSHIBA FAX I have Toshiba Fax showing error light blinking and toner empty. what can I do?
There was a chip in back side of toner if its memory erased it shows toner empty symbol.so you please replace the toner catridge to solve this problem
Posted on Jun 10, 2008
Toshiba E studio 182 power initialization problem
On startup, if the machine shows a wrench-icon, press down "8" and "clear/stop" key simultaneously to show the exact error-codes. A list of detailed error-codes can be found here: http://officeimagingsystems.com/id175.html
Jun 27, 2014 | Toshiba E-Studio 182 Copy Machine
When i start my toshiba e-studio 206 show Ink blinking icon
Please check the toner cartridge is actually emptied, if so replace it with a new one, if not, clean the contact of the chip, that locates in the back of the cartridge. You must use the genuine Toshiba toner cartridge, that has a chip circuit board on the back, those 3rd party cartridge created lots of problems, results lost of time and money that you would not like to hear.
Oct 29, 2013 | Toshiba E-Studio 206L Copy Machine
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
Oct 23, 2012 | Toshiba E-studio 2500 cbc939390, Copier,...
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Jun 03, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
My Toshiba E-studio28 Copier stopped working
its sounds like the developer is dry (out of toner) try opening and closing the front cover multiple times (no less than 5x) if it is still on you will have to call toshiba service provider to correct issue
Apr 29, 2009 | Office Equipment & Supplies
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
jasbo
jasbo
