Question about Samsung S630 Digital Camera
Card lock my camera works but everytime i put the memory card inside it say the card is lock
  • 46 Answers
Dear geogie:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Posted on Jun 09, 2008
  • David Bland
    David Bland Jun 09, 2008
    Dear geogie:
    Ignore that phone number. That's for Canon Tech Support :p
Hello, I owned a Canon EOS Rebel T1i and everytime I put the memory card, it says NO CARD. Any idea how to fix this?
Check if the Card is unlocked.
Remove the card, Check for a latch ( button ) on left or right side and change the direction to opposite.
Reinsert the card and it should work,
Few card need to be formatted first time when you you.
Nov 20, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Memory card error shows everytime camera is on
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Aug 06, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
"Card Locked"
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Sep 23, 2009 | Canon PowerShot A590 IS Digital Camera
Samsung d60
the memory card has a small lock in it u need to release tat it wil be at the side of the card scroll it down r up as per the detail it has
then u can use memory card
Mar 15, 2009 | Cameras
Locked camera?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jul 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card error/card locked
I don't know for sure, but since it is "grayed out," it MAY be that your camera can';t utilize a card that big (in gig's that is.)
Just a guess.
Mar 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Unlock card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Nov 10, 2007 | Pentax Optio 550 Digital Camera
Samsung S630 Digital Camera Logo
99 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
