SOURCE: Shift lever on column came loose inside column.
no, u shouldn't have to pull the steering wheel. pull the cover off the column, there are 2 or 4 nuts that hold the column up to the dash, remove them and let the column lay on the seat- u should disconnect your battery before doing so. you can get to the shift tube from there- most likely u'll find that the bushings have gone bad and need replacement.
SOURCE: grand marquis shifter broken
most likely it is the shifter tube that has broken. if you remove the lower dash panel and the column covers you can lower the column by removing the nuts holding it and have access to the tube
SOURCE: Shifter sloppy, having trouble getting it into gear.
You will have to pull the steering column apart to find out what part is worn out.
SOURCE: Ford Aerostar shifter on the column
check under the dash where shift linkage connects to shift cable will be two #30 torx bolts which have probably worked loose you do not have to remove wheel easy fix
SOURCE: 1998 chevy lumina, shifter on steering column,won't shift
Either the pin that connects rod to tranny is broken off, or there is internal transmission problems.
