Question about Microsoft Windows Vista Ultimate Edition
Big Problem !!!
Wenever i install Vista havin my Graphicz card in the slot there is a blue screen ....... or if i install it without the card it runs well but again wen i put it in slot.... same thin . . . .but in XP the problem occurs only during graphic intensive applications are run .....
My graphics card is GeForce 6200 256
P.S. : Once the vista thing did run and it ran exteremely well incl the arero stuff
Hope that u continue solvin thin n god solves thin fr u !!!
    Genius:
  • 1,601 Answers
Make sure that the graphic card is made for VISTA. If so, make sure that you use only the driver for VISTA, and any other software and driver from any other card is uninstalled.
Posted on Jun 10, 2008
HP a6750f monitor goes to sleep without warning right in the middle of something. Disc also sleeps sometimes (I hear it wind down) but blue light still on cpu, no yellow. Was running Vista, which problem...
Well FIRST take it back and make that "Repairman" work on the problem until solved at NO extra fee. What has been done is NOT professional. Had you come to my shop, this wouldn't have happened and if it did, it would be remedied without cost, and would be worked upon until fixed. The same must apply here. You paid good money for a FIX NOT OS replacement I suspect you have a faulty component,maybe Video card maybe WiFi card etc. Please do NOT accept a run around. Try the "Honey"approach first, then "Vinegar"... if, you get any BS, from them/Him. I am sorry on behalf of us professionals.
Mar 07, 2010 | HP Pavilion a6750f PC PC Desktop
Blue screen - Memmory_Management
You have the blue screen of death unless you have tweaked your PC to stop without restart it is difficult to read the error.
Did you upgrade from a x86 (32bit) ot x64 (64bit) version of Windows XP or Vista?
Windows (5) XP to Windows 7 - wet7xp_x86.exe
Windows (6) Vista to Windows 7 - Windows6.0-KB928635-x86.msu
Did you run the Windows7UpgradeAdvisor first ?
There maybe Memory Issues with your PC using Windows 7 especailly your Video Card Memory , it a good idea to check you motherboard for memory compatibilty some Motherboards wont take High Density Memory with Windows 7, check here at Crucial Scanner
If you post your HTML result of the Windows 7 upgrade checker to this post I maybe be able to help you further.
If all this fails I suggest that you do a complete install of Windows 7 unless you just have the upgrade pack, please check that you are using the correct version for your PC either 32bit or 64bit as shown above.
Please Rate my Answer
Nov 04, 2009 | Microsoft Windows XP Home Edition
Hello there. Ok. So i baught this video graphics card( geforce 8400gs) for dual screen purposes. Im running on windows Vista. I installed and loaded cd/dvd as instructed but no go. The video card has...
I encountered this problem, I do not believe it is a BIOS issue.
You should be able to go to My Computer, right click on it, go to device manager, and disable the onboard Graphics Adapter.
That being done your new video card should function without issue. Now for the DUal Screen issue,, Vista has a cute little feature where if it is a "basic" and not a "premium" version of Vista, it does not support multiple monitors.
I went back to XP with a bullet when I figured that out after hours of troubleshooting my video card
I hope this helps!!
Jim.
Aug 06, 2009 | Computers & Internet
I cannot install OS winxp onto sata drive pc is Acer aspire x3200
There could be two reasons for the blue screen either a bad harddrive or loose memory cards in the slots. Try reseating the memory cards on the motherboard.
Also please post back the Stop code you are getting on the blue screen
Thanks for using Fixya
proton
Jul 27, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
Hi I got some new SDRAM cards and put all of them
Each pair of ram stick go in the same color slot (2 x 1 GB in green for example) then the 2 x 512MB go in the other slots (may be pink)
you also need to make sure that your motherboard supports more than 2GB
Mar 25, 2009 | Computers & Internet
Installation problem with vista
Do you have an onboard graphic slot too . you could remove the XFX card for now . Install all other drivers on Vista first and then try your card again. Just try and single out the problem. Does the driver cd come with vista drivers ???
Jan 24, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
I Have been frequently havin blue sreen.Could it be my video card has a problem?
Blue Screen displays wen two or more Programs(Windows Aplication) tries to access one thing ...
in such case
you will have to upgrade your current OS
or
Its better you Install a clean OS(Format your drive and Install it again)
Dec 14, 2008 | Computers & Internet
VIA CPU to AGP Problem with 3Gb and Vista
Problem is you need to install Vista which support 4Gb! Look for specification on Vista you have!! Mostly XP and Vista support 2Gb!
The problem is in your OS. 32 OS support max 2Gb of ram they detect you 3gb but they couldn't operate with all!!
Jan 25, 2008 | MSI KT4V (MS-6712) Motherboard
Flight sim 2004 not happt with SLI configuration
Check page 2-19 section 2.5.6 of your manual. Also
Page 2-32
If this is all correct than swap known good card to second-PEG unsued slot. You could have a bad video card or SLI cable.
Dec 28, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Microsoft Windows Vista Ultimate Edition Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
