Question about Refrigerators
Frequent frosting over
I have a GE side-by-side GSS22WGMD that frosts over every couple of weeks. Usually the first sign is the water dispenser line freezing up/vegetable drawer contents freezing and the fridge side gets too warm. When I get to the freezer coils, they are totally iced over. I defrost it, it regulates the temp okay for another couple of weeks and then repeats the cycle. I've replaced the circuit board, which seemed to fix the problem for about 6 months, but now it's back to the same old frosting over cycle. Help!
  • Anonymous Mar 08, 2009
    we have a g e side by side that does the exact same thing
  • v8extreme Mar 09, 2009
    same thing with mine too!!!!!
  • 868 Answers
Replace the defrost heater thermostat
PLEASE RATE THIS !
Posted on Jun 09, 2008
Frost forms on the inside opening of the chute for the water/ice dispenser. Also frost on the exit chute from the ice cube tray. The frost is present a day or so after I clean it off.
The door flap which releases the ice , on the door , is not closing completely .Usually this is caused by a rusted plunger so both the solenoid and plunger will have to be replaced , These parts are located behind the dispenser board so be sure to remove the top freezer door hinge cover and unplug the plug there , to remove all power going to the door , before attempting this repair . I think the part number is WR62X10055 for the kit .
When it doesn't close , it lets warm air into the freezer and causes frost on the dispenser AND on the ice bin outlet . Also , using 10 glasses or more , of crushed ice a day can cause this .
Aug 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
I have a ge gsl25jfta bs, it is a frost free refrigerator but recently it is developing lot of frost around the water dispenser area(inside). It started when my water dispenser had stopped working and i...
Sounds like the flapper is not shutting completely. Open the door and look into the door flapper hole from the inside. If its not closed its either stuck (push closed from outside) or broken. If broken you will need part replaced
Oct 05, 2017 | GE Refrigerators
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS25 continuely has frost on cube chute preventin cubes from discharging. Have had doors replaced under recall but problem came back.
I had the exact same problem. My neighbor has the same refrigerator, and told me that there is a solenoid in the door, behind the panel where you select between water, crushed or cubed ice. You can carefully remove that panel to expose the solenoid, which is on the right side of the dispenser water line. I have the model GE GSS25. The plunger on the solenoid gets rusty buildup on the outside of it from the moisture and water splashing from the dispenser. You might try wiping the exterior of the solenoid, and working it up and down so that it moves freely. If not, it's a cheap replacement part you can order from GE. The solenoid shuts the trap door which opens when you get ice from the dispenser. If the solenoid plunger does not move freely, then the trap door hangs open, and warm moist air enters the freezer through the ice shute, causing frost.
Sep 16, 2009 | GE GSS25JEMWW Side by Side
Fridge warm
The frost build up is blocking the flow of cooling air from reaching the refrigerator section. If you take the cover off the frosted area and melt the frost off with a hair blower your refrigerator will work fine for a few days to a couple weeks, and then the problem will show up again. You need to determine why it is not defrosting by itself. You do not list the model number or even an aproximate age of your unit, so I can not be very specific with a solution. Test the defrost heater and then look at the defrost control timer. Also, look for any signs of air leakage into the refrigerator, such as a poor gasket (look at the bottom of the fresh foods gasket in particular) or a dispenser area if your model has a through the door ice dispenser.
Jun 21, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
522 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
