Question about Philips 27PT543S 27" TV
TV Picture No Longer Comes On
When we turn on our Philips 27PT5633S 37A, the power light comes on, the TV clicks, but there is no picture. Before it completely stopped working, each time we turned on the TV, it would take longer and longer before the TV turned on, until it stopped coming on.
Any assistance would be appreciated.
  • Anonymous Jun 12, 2008
    Same thing. Finally the clicking stops, but now the green indicator light does not turn on and the back of the TV chirps. What parts do I need to get and where could I find them?
    Problem Solver:
  • 4 Answers
Sounds like one or multiple Reservoir Capacitors in the Power Supply were starting to dry up. You also get problems like this from dry joints in the Power Supply. You need a technician to take a look for certain.
Posted on Jun 09, 2008
Tv will not turn on
I would start with having the power supply capacitors checked. If they are the culprit, they are easy and cheap to replace.
Apr 03, 2013 | Philips Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Power button comes on but no sound or picture
change the resistor in the relay circuit as they go high in value
also when you take power supply panel out check all caps for bulges etc.
Aug 26, 2009 | Philips 42PF9431D/37 TV
Clicking sound in back of tv when you try to turn it on
Sounds like this could be a dry soldering joint in the TV power circuit. This can easily be repaired with a small soldering iron and soldering wire.
Best wishes,
Graemevm
Jun 06, 2009 | Philips 27PT543S 27" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 27PT543S 27" TV Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
