Question about Lexmark JetPrinter X1185 All-In-One InkJet
HP LaserJet 4250
I can't install the printer because it's says the print spooler service is not running. How do I repair this?
  • 1,031 Answers
Go to Start> Run > CMD and press enter, then type 'net start spooler' for further trouble shooting as to why it is not auto running, go to Start> Control Panel (in classic veiw) > administrative tools > services
in there you will find print spooler, make sure that service is set to automatically run, you can also start the service from there and if it can't run it will give you the error as to why
Posted on Jun 09, 2008
I can not print on my HP Laserjet 1020. It first asks that I install a printer before printing but when I try to install the printer it says that the local print spooler service is not running. It then...
try to restart the spooler system.
to do it:
1) click start
2) on the search box type Services and hit the enter key
3) on the windows that appear after you hit enter. Find priter spooler
4) once you find it. double click it.
5) on that window. and make sure that the startup type is automatic and finally click start.
Note: if the spooler service is already running stop it and restarted back in.
hope this helps
Jan 18, 2011 | HP LaserJet 1020 Printer
Hp 4250(on a network) is hung up on processing job. I restarted the print spool and physically restarted the printer put the problem still exists.what should i do
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Jan 07, 2011 | HP LaserJet 4250n Printer
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
The printing spooler service is not running.
Go to the control panel. Select printers and right click on your printer. Select properties and turn print spooling on.
Aug 08, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
HP Laserjet 1020 Spooler not starting
First uninstal old drivers then install again.
Then go to start menu then type in run "services.msc" then press enter
then you can seee right pane check there you find Print Spooler just double click on it then set
stratup type as automatic then click on depndancy tab then set restart the service .
then apply and ok.
Jul 15, 2009 | HP LaserJet 1020 Printer
Print spooler service not running
This means your printer is not correctly installed. Please remove the installed driver and printer from the PC and then follow the steps given in this TIPs N Trick by me:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Nov 04, 2008 | HP LaserJet 1020 Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
