Question about Frigidaire Washing Machines
Error code E10 on frigidaire GLTF2940ES FRONT LOAD WASHER. WHAT DOES THE E10 ERROR CODE MEAN.
  • Anonymous Aug 24, 2008
    e1o error code
  • Anonymous Mar 31, 2014
    error code E10
  • 31 Answers
Possibly a long fill error code, clean out the screens in the water valve
Posted on Aug 25, 2011
I solve this problem today on mine. I didn't have the door close right or the sensor is going out. I just slammed the door and tried and again and it worked. I may be overloading the machine.
Posted on Jan 09, 2010
I have the same problem.  I'm going to search the frigidaire web sight
Posted on Aug 07, 2008
E10 code occured after the start of the Normal wash cycle. No water entered into the machine
Hello
A e10 error is water supply,usually clogged screens in the hose hookup part of the machine.
Remove hoses and unclog and remove any debirs from the screens.You can use a toothpick or a small tooth brush.
Unplug machine while doing this.Once done and screens are clean,hook hoses back up and try washer again.
Apr 22, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
E10 on washer
this is just a general fault code.chance are the door switch needs to be replaced.you can also check to see if there is something clogging the drain pump.
Jan 23, 2010 | Frigidaire GLTF2940ES Front Load Washer
What does E10 code mean?
Try reading this.
http://www.technicianbrian.com/2008/06/frigidaire-washer-long-fill-and-e10.html
Sep 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 error on Frigidaire GLTF2940ES
I searched the internet for a list of error codes for the washing machine. The E10 error code indicates an interuption in water supply among other things. We checked the supply lines and found that the screen on the cold water line had been blocked by sediment ( we have well water,and just replaced the pump).
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error code E10
tech sheet located inside behind lower panel on left.
Apr 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
"e 10" error code
E10 usually means hot and cold water lines are reversed or your cold water supply is lacking ie: low pressure, clogged etc. Hope this helps
Aug 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
754 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
