Question about HP Pavilion dv6000z Notebook
Blue screen shutdown on my hp pavilion
My laptop just shutdown attimes wen am usin it. a blue screen comes up and it rites dumpin physical memeory or so nd then it restart. pls i need to know wats up nd wat to do
  • sayoung190
    sayoung190 Jun 09, 2008
    but my laptop cam partitioned so i dont av a cd dat came wid it
  • 191 Answers
You need to perform a repair of operating system using windows cd which came along with the system
log on to microsoft's website and get info how to perform a repair.
http://support.microsoft.com/kb/315265
Posted on Jun 09, 2008
Screen rolls and is jittery
If you have room to install extra memeory, do so and see what happens. If you still have the same problem, it could be that your video card is defective.
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
Hp Presario 2000 will not get to windows sign in
Do you see an error message on the screen or, does it blue screen with an error message? When you boot up press F6 just as the PC drops out of BIOS mode. Select "Last Known Good Configuration". If that doesn't fix it, look up the error code on the blue screen with Google. Most blue screens are fixable. Some require a complete rebuild of your hard drive.
Aug 25, 2013 | Fujitsu LifeBook S6510 Notebook
How to fix unexpected shutdown due to Blue screen problem of Pavilion HDX9494NR
See if the Check disk utility will solve your problem. To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | HP Pavilion HDX9494NR Notebook PC
Blue lights come on but screen will not come on or
see care fully at ur screen with in some external light
u see somthing check ur laptop to an external monitor
if working?now ur lcd problem
Jan 27, 2010 | HP Pavilion dv9000z Notebook
I have a HP Pavilion PC that popped up a blue screen & shutdown
It is your harddisk bed indexing issue.
For that first boot your laptop with winxp bootable disk or recovery disk.
Then follow the procedure.
Then when it ask for winxp installation press enter then choose "R' for recovery console mode.
Then enter 1
then press enter
then type in prompt "chkdsk /r'
then it fix error on disk.
then check .
If after this still winxp not load thne you have to repair winxp
For that follow the same procedure but now you have to choose option "r" for repair winxp .
Let me know if you need more assistanse .
Thanks.
Aug 26, 2009 | HP Pavilion tx1000z Notebook
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
Blue screen physical dump error
Hi
They virtual memory should have been exceeded the limit.
Step 1:
Power Drain:
1.Disconnect all the cabled from laptop, including Memory card and wireless card(wi-fi)
2.Take out the batteries
3.Press and hold the ON button for 30 seconds
4.Put the batteries in and boot the laptop.
if its does not works
Step 2:
Upgrade the RAM memory of the Laptop
Thanks
Riz
Jan 13, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP 510 notebook will not start up
I seems your internal RAM might be damaged. If you bought it new an dit is still under warranty, go back to your vendor and have it repaired. If out of warranty, you can try to purchase new RAM module and replace it (or have it done).
Aug 15, 2008 | Computers & Internet
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Blue srren fatal error
you was probably installing updates in the background and youve interrupted install and shutdown improperly (reason)
turn on pc and press f 8. if youve never done this before;as soon as you see anything at startup keep pressing f 8 youll still get to the place you want to be.select start up using last known good configuration.
Mar 02, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
