Question about KitchenAid 31 in. KGCS105 Gas Cooktop
Disassembling kitchenaid gas cooktop to replace the ignitor switch
  • Anonymous Jun 11, 2008
    The ignitor on my kitchenaid gas cooktop stop working...I can use a match to light the burners but I would rather not do that. How do I fix this?
  • Anonymous Sep 01, 2008
    I need to replace one of the ignitor switches I guess (on my KGCT305T WH KicthenAid glass cooktop). The little protrusion on the switch that gets pushed to start the ignitor, when the knob is turned, has broken off. I am not sure how to open and reach the switch. The bottom has a bunch of screws that I removed. But the bottom cover won't budge. I did not use force since that could break something or shatter the glass. Can the glass be opened from the top? How do I get to the switch?
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 21, 2010
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
Watch my video How to disassemble most kitchenaid and whirlpool cooktops - this situation is typical when screws wont come off
Posted on Feb 22, 2014
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: electric ignitors will not shut off gas cooktop range
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Jul 25, 2010
Ignitor clicking constantly
2 POSSIBLE PROBLEMS: 1ST - SPARK SWITCH ON ONE OF THE BURNERS GOT STUCK, OR 2ND - SPARK MODULE IS BAD. HERE IS THE VIDEO INSTRUCTION HOW TO DISASSEMBLE KITCHENAID COOKTOPS AND HOW TO REPLACE THOSE PARTS. HOPE IT HELPS.
Sep 22, 2012 | KitchenAid Cooktops
Ignitor stays on
Hi dalal5,
The ignitors on your Cooktop have gotten wet, or where exposed to moisture.
Please follow my instruction on the Tip below to rectify the problem:
GAS COOKTOP KEEPS CLICKING...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 14, 2011 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
I have a KitchenAid gas cooktop, model jgc853adb. The ignitor sparks all the time unless I unplug the unit. Any help?
Hi aschaper,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 26, 2011 | KitchenAid Cooktops
I have had my cooktop for 5 years The ignitor stays lit when cooking and I have had to replace the ignitor for the grill 4 times. Why is this happening?
You are getting too much water around the knobs...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 12, 2011 | KitchenAid Architect KGCP484KSS Gas...
What causes gas igniter to keep clicking when gas is off
Sounds like someone washed down theb cooktop. If the moisture traveled throughout the contacts, the clicking sound will continue while off, until things dry out. Unplug cord from wall, give it some hours, maybe even a day or so, for moisture to evaporate. This worked for me in past. Give it a try. Good luck
Jul 30, 2010 | GE Profile JGP636 Gas Cooktop
Electric ignitors will not shut off gas cooktop range
this video shows how to replace everything on your cooktop, at will help you troubleshoot!
Jul 22, 2010 | KitchenAid 31 in. KGCC505 Gas Cooktop
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
Jun 20, 2010 | GE Profile JGP636 Gas Cooktop
My kitchenaid gas stove continues to try to ignite making popping sounds
Here You can see how to disassemble Kitchenaid cooktop. I replaced everything on this one, since I knew its a big job, decided to do everything at once. Problem is - cooktop is dead, no spark to any burner. I hope it helps! Thanks! How To Repair Whirlpool KitchenAid Stove Cooktop HD 1080
Apr 24, 2010 | KitchenAid 31 in. KGCS105 Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
KitchenAid 31 in. KGCS105 Gas Cooktop Logo
1,867 people viewed this question
Top KitchenAid Cooktops Experts
vince
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
