Question about Mintek DTV-263 26 in. LCD Television
Fuzzy no channels
The TV is fuzzy i tried to rest the channels but it does not work,
    President:
  • 1,284 Answers
If the inputs look normal then you might have a issue with your cable and or antenna. Does the TV have 2 antenna inputs? If so try the other one if it works ok then the antenna switch is defective. If not then the tuner is bad.
Posted on Jun 09, 2008
Only a few channels are able to be seen. the rest
Check cable and that no devices between cable and tv are turned on.
Mar 15, 2010 | Hitachi 42HDS69 42 in. Plasma Television
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Channel 2 goes fuzzy same time each day
This may be an issue with the broadcast. As all other channels are fine its not the tuner or TV. The broadcasters may be doing work on this channel at the same time every day.
I would advise contacting the people who broadcast TV in your area
Jul 15, 2009 | Televison & Video
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
ALL MY CHANNELS HAVE A BLACK PICTURE & FUZZY, PLEASE HELP
first off how good are you with a solder iron ? beside the obvious rf connector problem these set's had problems with bad solder connections within the tuner itself. google( sam goldwasser repair faq) for the solder template.
Jun 10, 2006 | RCA F27252GY 27" TV
Mintek DTV-263 26 in. LCD Television Logo
62 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
