Question about Frigidaire Washing Machines
I have a Frigidaire washer # FWS445RF. Water is not cutting off after starting. Overflowed. Spin cycle works and drains. We just can't get the water to cut off.
    Genius:
  • 1,073 Answers
Replace the water inlet valve that the fill hoses connect to
Posted on Jun 09, 2008
Spin cycle does not remove excess water (worked great till recently)
EITHER A LOOSE WORN OR BROKEN BELT, A LOOSE SLIPPING CLUTCH A BAD DOOR SWITCH
Apr 09, 2014 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Fws445rf1 washer didnt stop filling and flooded my apt and it doesnt aggitate when it is washing,the whole thing just spins inside instead of moving back and forth,what are the most likely reasons for...
if it's a top-loader, then the water level sensor is probably failed! if an older machine- there's a plastic tube (which you can't see from the outside) that measures the column of water in the tub of your machine, and triggers the agitate and spin, and rinse cycles of your machine.
when it's in wash cycle the water level is lower, then it spins and drains and the rinse cycle pumps in more water (makes sense!), then drains & spins, then re-rinses at the same water level. your water level sensor is defective, probably. allowing it to over-fill.
it detects the water level as 'spin' and doesn't agitate!
my theory- no guaranty! if it's old get a new washer or a good used one! this is not a problem i've encountered, just a guess. good luck!
Apr 17, 2010 | Frigidaire FWS445RF
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washert not draining
If your washer spins but doesn't pump the water out, the drain line might be clogged.  In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. You already have replaced the pump motor and still no operation,  so check the power voltage to the pump during the drain cycle.   Verify the problem is not pump related as much as power to the pump being the problem.
Mar 15, 2009 | Frigidaire FWS445RF
Washer will not drain
Your outlet filter is probably clogged; this requires periodic cleaning according to usage. Clean this out and refit. Ref manual. Be prepared for water to come out of the front so keep some towels or pan handy.
Sep 03, 2007 | Frigidaire FWS445RF
Timer is not working
Mom, it sounds like a timer issue, not advancing. If your model number ends in RFS0, your part number would be 131436800. Cost of the timer is around 90.00. This is not a hard repair. Catriver..post back.
Sep 19, 2006 | Frigidaire FWS445RF
9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
Jun 11, 2006 | Frigidaire FWS445RF
Washing Machines Logo
138 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
