Question about Microsoft Wireless IntelliMouse Explorer
Microsoft Intellimouse Explorer 2.0 Battery Problem
I've been using this mouse for a year or so now and up until now battery changes have been fine. When the clicking function was starting to become irresponsive, as it does often times when the batteries get low, I went and changed the batteries.
However, the mouse now does not work at all. I've tried using multiple sets of batteries but the cursor on my screen does not move at all now. I've tried reconnecting the signal taker thing and also attempted to connect a wired mouse, but the cursor still won't move. I know that the lights on both the mouse and signal taker thing go on and I've tried moving them different distances appart, still no go.
Any ideas on how to fix this?
  • 1 more comment
  • Anonymous Nov 01, 2008
    yeah same the mouse started to become unresponsive and i tryeed changing batteries and now it stopped working the red light wont come online as well
  • myklops Nov 05, 2008
    i have almost the same problem. my wireless intellimouse explorer 2.0 worked before i turned it off. After 20 minutes, i opened my laptop again and there i found my mouse not working.
  • edg0000 Dec 11, 2008
    Similar problem. wiht my IntelliMouse. it sometimes takes anywhere from 2 to several clicks of the left button to activate something on screen like a web link or a file in Windows Explorer. According to Mouse Properties, both the battery level and wireless signal strength are full green. I have replaced the batteries and the problem remains.
    The strange thing is that if I press the buttons on the transmitter and the mouse to re-set the wireless signal then the mouse works fine, at least for a few minutes until it starts requiring multiple clicks again.
    Any ideas?
    President:
  • 2,712 Answers
You say that this has been happening with a wired mouse as well?
In that case, you probably have a kind of virus/malware. Try this first:
http://housecall65.trendmicro.com/
Do a full system scan. You may have to temporarily disable/uninstall your current anti-virus if you have one already..
If not, try a system restore.
Posted on Jun 09, 2008
MS Intellimouse Explorer 2.0 scroll wheel only scrolls down
There are number of reasons and solutions why your mouse isn't working properly. No.1. Resynchronize your mouse to the Pc. It's best to use the reset button for resynchronization. No. 2. Change the Port (Usb port). Sometimes even the small problem with the port created this problem. No.3. Replace the battery. If you are sure about the battery is Live, you can try with another make eg. Sony to Everydy. No.4. Interfaces Problem. Make sure that no electronic items, metal box, Speaker, etc doesn't obstruct the connection. No.5. Driver Update. Update the driver to the latest version. You must update from the particular website. If you are using Microsoft product, you must update the driver from the Microsoft's website. No.6. Different System. Try out the device on several devices not only one. If you still have difficulty, you can visit this site for more details. http://support.microsoft.com/kb/838398 Good luck
Apr 29, 2010 | Microsoft Wireless IntelliMouse Explorer
Left mouse key is sticking on Microsoft optical intellimouse
You need to replace your mouse my friend. I guess its time for it to rest.
Apr 08, 2010 | Microsoft Intellimouse Explorer OEM Pack...
My Microsoft Bluetooth Mouse will not stay connected to my system
1. Go to Start->Run and type in "services.msc" and click OK
2. Find "Bluetooth Support Service" in the list of services and double click to open the properties window
3. Click on the "Log On" tab and select "Local System Account" for "Log on as:"
4. Click Apply and OK
5. Right click on "Bluetooth Support Service" and select stop then right click on "Bluetooth Support Service" again and select start
6. You may need to reconnect your bluetooth devices; everything should be working now.
Nov 18, 2009 | Microsoft IntelliMouse Explorer Bluetooth...
Strange situation that I am getting annoyed with. Here's what the deal is: I have a Wireless MS Intellimouse Explorer which actually works fine but, the intellipoint software (nor device manager) does...
Sounds like you need to update your mouse's driver, you will find the intellimouse 6.3 driver for Windows XP at the link below "IntelliPoint 6.3 32-bit for Windows XP".
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=MK&type=Mouse&name=m_imobt&os=XPSP2&lang=en
Feb 22, 2009 | Microsoft Wireless IntelliMouse Explorer
MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless IntelliMouse Explorer 2.0 - low battery pop up
I would disregard the pop up as in most cases the batteries are still good. I'd use the mouse till it stopped functioning. Why it does that I haven't figured out yet. I beleive a value has to be changed in the Registry. If I figure it out I will let you know.
Bud
Jan 22, 2009 | Microsoft Wireless IntelliMouse Explorer
Couldn't find the answer to the right click mouse button not working.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 16, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Mouse pointer has disappeared
Recalibrate your mouse and transmitter by pressing the button on the transmitter as well as the mouse. Make sure there in a range no more than 30 ft of each other.
Aug 11, 2008 | Microsoft Wireless IntelliMouse Explorer
Wireless IntelliMouse Explorer 2.0 problems
Make sure the batteries are good and try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Mar 02, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless IntelliMouse Explorer Logo
197 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
