Aitconditioner air not blowing cold, return line frosted up?
  • 1 more comment
  • Anonymous Jun 09, 2008
    I have a carrier unit. Fan and condenser are running, but no air coming out of vents from first or second floor. Thermostat seems to be working fine.
  • ddsw Jun 09, 2008
    I have the same problem. We have two zones. The unit for the upstairs has only been used for 2 seasons. The thermostat is fine, the unit will turn on, but blows only semi-cool air and cannot cool upstairs of our home.
  • burzerko
    burzerko May 11, 2010
    is it the larger of the two lines that is freezing up?
    Champion:
  • 254 Answers
If it is the larger of the two lines check your filters in your inside unit. Also check to see if the fan is blowing. If both of these are ok most likley you are low on refrigerant.
Hope this helps
Posted on Jun 22, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Circuitboard or fan motor, (backtrack from the fan motor voltages)!
Posted on Jun 09, 2008
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Danby Heating & Cooling
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
MOTOR IS RUNNING BUT NOT GETTING COLD
you say motor do you mean the compressor, if so is it making any heat if so it says it is trying to work. common problem if so is a frost build up in frezer on back panel keeping cold air to circulate to refrig. from freezer. also check to see if freezer blower fan blowing air. back to compressor, it has large return line should be cold and a smaller high side line usually 1/4 inch and this should be hot if compressor is doing it's job.check cooling motor by compreesor also to much heat will shut it off.
Nov 08, 2010 | Refrigerators
I have a Rheem 10 series ac that is only 11 years old. The coils are clean inside and when i opened up the unit outside and ran water over the compressor and frosted lines, the unit appeared clear of any...
TO LO OR HIGH!!! ALSO THE FILTERS COULD BE DIRTY OR AN AIR RESTRICTION IN YOUR RETURN AIR DUCTWORK OR DUCT IS NOT BIG ENOUGH.{ NOT ENOUHG AIR BLOWING ACROSS THE INDOOR COIL} IF THE UNIT ISEQUIPPED WITH A TXV THIS COULD BE CLOGGED AND WILL HAVE TO BE REPLACED BY A CERTIFIED A/C TECHNICIAN. FIND A FRIEND WHO HAS A TRUSTED AND HONEST A/C GUY... GOOD LUCK
Oct 17, 2010 | Heating & Cooling
Air conditioner not blowing out enough cold air fan is working but frost is built up outside and in on lines
Sounds like the unit may be Short on refrigerant, the frost can be sign the refrigeration is taking place on the pipework between the indoor and outdoor unit and not on the internal coil (evaporator indoor unit)
All the best
Jul 05, 2010 | Heating & Cooling
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
Freezer temp 7-20, ref temp steady 35. Ice on return line
HI thanks for your question. the way that frost builds up on the return line is the freezer is running too long . you have the temp set at too cold a setting 34 deg is too cold. it should be 36. 37. other wise frost builds up.thanks the appliance doc. please rate my answer. thanks.
Aug 13, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Compressor lines
If the large line returning to the compressor is frosting you don't have enough air circulation. Check air filters on inside unit.
May 12, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
