Question about Asko Washing Machines
We have a code F3 on our asko washing machine
  • 3 Answers
Most likely a drain pump problem. Make sure there is nothing in the drain hose. Then it would be a bad drain pump
Posted on Jun 16, 2008
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
F3 error message
Hi, Welcome to FixYa. The F3 error for an Asko washer indicates a problem with the pump or a blockage in the pump. Remove the pump insert/filter and clean it and check inside the pump and hoses thoroughly. Let me know what you find or if you need more help/direction. Good luck. Regards, Macmarkus :)
Oct 26, 2010 | Asko Washing Machines
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 30, 2009 | Asko W6441 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Fault code f3 on asko wm 200 washing machine
blockage in pump or the drain hose sink end if it under the sink
Aug 19, 2008 | Asko Washing Machines
Asko W6431 Quattro front loader
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Apr 24, 2008 | Asko W6021 Front Load Washer
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Washing Machines Logo
125 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
