Question about Ricoh Aficio CL7000 Laser Printer
Printer Problem I have an imprint of something (a rubber band?) in the middle of each page after printing.
    Problem Solver:
  • 3 Answers
I had the same issue, take a look at your transfer belt, it probably has a tear in it. That's why it's every few pages, if it were a drum it would be more consistent. Good luck.
Posted on May 18, 2009
    Scholar:
  • 68 Answers
Is the "imprint" in the same spot on every page?
It the spot white (no toner) or black/color (toner)
Is is most probably an imperfection (scratch) on on of the image drum.You can remove and inspect, just don't thumb the actual drum when you do. It could also be one of the developer units. They can also be replaced.
Posted on Jun 09, 2008
I HAVE REPALCED THE BATTERIES AND IT WILL NOT POWER ON.
The HP 32SII calculator has a very common problem with the keyboard connections. There might be nothing else wrong with the calculator except the contacts.
Try pinching the calculator just below the middle of the screen above the [LN] and [Y^x] keys while pushing the [C] button to power it on.
If this worked, at least you know where the problem is. Fixing that problem temporarily, some users wrap a rubber band around the calculator at that point and put something under it to keep pressure on that spot.
The longer-term fix is harder and involves taking the calculator apart to replace a foam pad to keep pressure on the plastic keyboard contact strip against the printed circuit board contacts.
Somebody (not me) put together an Instructables page for the HP 17B calculator, which is built exactly the same as the 32SII.
HP 17b series calculator repair
Nov 30, 2015 | HP 32Sii Scientific Calculator
Ghosting
Normally ghosting is caused by a bad fuser.
Put paper in the manual feed tray(tray 1)
Print something. As the paper gets 1/2 way into the printer, open the cover..
Look at the paper. If there is no ghosting, the fuser is bad. If there is ghosting, could be a cartridge drum.
Follow these steps print a Print quality troubleshooting page to identify which print cartridge is causing the issue.
  1. Open Toolbox .
  2. Click the Help folder, and then click the Troubleshooting page.
  3. Click Print , to print the page. The page prints five bands of color, which are divided into four overlapping sections. By examining each section, you can isolate the problem to a particular print cartridge. Figure 4: Print quality troubleshooting page bandsc01417618.gif 1 - Yellow 2 - Cyan 3 - Black 4 - Magenta
May 01, 2011 | HP LaserJet CP1215 Color Printer
How do I turn off the date imprint on my SP 800 uz ?
For what I can see, there is no standard date imprint on the pictures other than in the PRINT menu.
See the Olympus SP-800uz user manual on page 51, point 5.
Apr 16, 2011 | Olympus SP800UZ Digital Camera
HOW TO HAVE DATE IMPRINT ON PHOTOS..? DIRECTLY TO JPEG
As far as I have experienced, there is no setting for imprinting the time/date directly into the pictures. There is an option to print pictures with time/date, see user manual page 51, point 5.
You can however manually imprint pictures with any decent graphic program, looking at the timestamp of your pictures.
Feb 19, 2011 | Olympus SP800UZ Digital Camera
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
Have a line accress the copied page. already cleaned the glass
The Reason in block of the scene or in develope block. Assign copying and stop the main switch off in that moment, when sheet is found in middle of the way. Open the device, when you take out the stuck paper in the same way and see on imprint on sheet of the scene if band exists, or on paper or on cylinder, that problem in block of the scene. Analyse the block and extract the perfected toner. Such can be, when perfected toner overfills the container. I think in this reason
Sep 22, 2009 | Office Equipment & Supplies
Rubber band slipping to edge of the silver spoke
Hi thanks so much - the vacuum is an upright morphy richards model number 73360.
We kept re-alligning the band into the middle and rolling the brush round several times with our hands to make sure it wouldn't spin off. The roller that the band fits on is very wide so you just put the band in what you think looks like the middle.
It was unbelievably sensitive and had to have it "exactly perfect" to the millimetre otherwise the band would just continue to slip off. It appears to be working for now so lets see how long it lasts before the smell of burning again! Many thanks for advice.
Aug 15, 2009 | Vacuums
IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Sep 22, 2008 | Lexmark Wheelwriter 3 Typewriter
Printer prints dark middle stripe on every page?
remove the cartidge and replace with a new one,
clean the rubber roller and check all drivers are installed correctly or that you have the most uptodate versions.
if this doesnt help solve it, you could invest in a printer repair kit specified for your printer usually found in p.c shops..
if all else fails call up the company.
Oct 22, 2007 | NEC SuperScript 1400 Laser Printer
Ricoh Aficio CL7000 Laser Printer Logo
183 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
