Xerox xc1020 needs repaired
Need to have help in getting a copier repaired. It keeps running but will not allow you to print. The green light shows it needs paper but we but paper in and it still runs and does not print when the print button is pushed. Any help.. Where can we take it to get repaired we live in NW Missouri. ?
  • 81 Answers
Make sure your toner cartridge has toner in it. It sounds as though the copier is trying to tone up. I dont know anyone in Missouri, but you could ship it to us in Indiana if you wanted to.
Posted on Jun 09, 2008
Where can I find supplies (Drum and Toner) for old Xerox model XC1020
The black toner cartridge is available through Amazon.com http://www.amazon.com/Brand-Genuine-Xerox-Cartridge-Designed/dp/B003KIYZSC . This site has the drum: http://www.tonercartridgedepot.com/xerox-xc1020-3433-d.html .
Some other sites list the supplies but these list them as In Stock today.
I hope this helps.
Jul 08, 2011 | Xerox Office Equipment & Supplies
Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
Hope this helps.
Dec 25, 2010 | Xerox Phaser 8500/DN Printer
My xerox Phaser 8560 is printing green? It was working fine but now All my pictures have a green hue. Why
I need to know something first. If you print a test page, an internal page, a confirmation page, menu page, etc, does the machine give you a green hue ?
Have you tried to shut the printer down and allow it to reboot? There is tec color correction on your print driver properties. You can try adjustments with that.
But first let me know if the internal prints are ok , then lets go from there.
Jan 18, 2010 | Xerox Phaser 8560DN Laser Printer
Xerox XD100 that is showing a code J2
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Jul 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Xerox XC1020 copier and the drum light is on...
No, What happens is on that drum unit , under the green front cover there is a series of gears with a small flag on it. That flag makes one rotation when the drum is installed and actuates the new drum switch. What has happened is that flag has dropped while in the box and never reset the switch. You can pop that green cover off and reset that flag to the up/right position, approx the 2 o clock position,, Or you can exchange the cartridge. That is very very common on that cartridge for it to drop in shipping.
Mar 10, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XC1020 Flashes code H 4
This should resolve your issue. If not it would most likely need a heat rod. But there ia probably a 99 percent chance this will cure it. Let me know please.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Feb 16, 2009 | Xerox Office Equipment & Supplies
I have a Xerox xc1020. it will not work. when i turn it on it moans, and than will try and warm up for a long time. can you help me
Wait a minute. I just answered this question to your name for an M20.. On an XC1020, that is different. If that is moaning I strongly suspect the toner cartridge if it just sits there and chugs without faulting out. Could be the drum . If it were the motor on that machien it would fault out. Now it depends on the model.
If it is an XC1020, I very strongly suspect the toner cartridge.
Again, let me know,we will start at the toner and drum on that one.
Jan 22, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XC1020 White Bands running across copied page 4" apart
The metering blades in those cartridges go bad and do not allow the ink to get to the page. Look at the front of the toner cartridge, is should be a solid consistent black all the way across, if its streaky, not consistent all the way across replace the toner.
The other problem could be a dirty laser. If replacing the toner doesnt work let me know, I will tell you how to remove and clean the laser.
Jan 16, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XC1020
1st you need to know what error code it is giving to know where the problem is coming from
Sep 23, 2008 | Xerox CopyCentre C20 Black and White...
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
61 people viewed this question
jasbo
jasbo
