Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE D52GW12 turns off
We bought our GE D52GW12 in 2004. Recently it started turning off just after 5 min. When tried to turn it on after 10 min or so, it would work sometimes. Yesterday it stopped turning on at all. When pres the button or remote we hear crackling noises and nothing else happens. What is the problem? Thanks!
  • 4 more comments
  • Evasz Jun 09, 2008
    Are getting your D52GW12 fixed or buying a new one? Have you looked into the cost of fixing it?
  • deange22 Jun 24, 2008
    The TV has worked fine for a few years, now it will shut off after running for a little while. It will turn back on by it self sometimes, or it wont come back on at all. It has been happening more and more frequent and last night it wouldn't turn on at all. The power light comes on and shuts right off again. What should I do?
  • doctor_dr2 Jun 24, 2008
    Same problem. TV manufactured in 2004. Sparks, smoke, etc etc. I didn't have a TV repairman look at it, but I talked to one and he said about $300 to $400.
  • greenlee Jul 05, 2008
    I am having the same problem, is it the flyback or the power mod?????
  • markeeemark May 03, 2009
    We've had the TV for about 4 years...recently, we would watch tv and it would flicker on and off or completely shut off...We would wait a few minutes and turn back on only to have it shut off again. Every now and then, it stays on, but it is gradually getting worse.
  • elgin29 May 04, 2009
    i have the same model but it comes on and you hear a beep or sound but not picture.
We bought our GE D52GW12 in 2004. Recently there was a severe power outage and now it started turning off just after 5 min. When tried to turn it on after 10 min or so, it would work sometimes. Yesterday it stopped turning on at all. When pres the button or remote we hear crackling noises and nothing else happens. What is the problem? Thanks!
Posted on Jun 11, 2008
I have the same problem, what the heck. it's over for it
Posted on Jun 09, 2008
GE D52GW12 TV TURNED ON WORKED GOOD FOR 3 MIN THEN SHUT OFF . WENT TO TURN IT ON AGAIN AND GREEN POWER LIGHT BLINKED AND HERD A POP OR CRACK NOISE ..NOW DONT TURN ON . SEE 1 OF THE TUBES FLASH IN FRONT 1...
The CRT on the left will need to be replaced. You can test it by removing the CRT drive board from the bottom of that tube and leaving it suspended without unplugging any wires. try plugging it back in and pressing power. If it powers up with that drive board hanging off the bottom of that tube then you know thats the issue and the CRT ( tube) will need replacement. You can get the replacement CRTs ( tubes) from www.tvrepairworld.com
Jun 14, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
My GE D52GW12 52 in TV only turns on after I push the power button numerous times (sometimes up to an hour). The green light on the power button comes on but kicks off after about 5-10 seconds. It is...
Thats a very easy repair which is almost always related to failed power capacitors CP150, CP120 and CP114. You can get the RCA repair kit which is the same as the GE from www.tvrepairworld.com the kit is called the ATC221 CP150, CP120 & CP114 repair kit . The kit contains the caps and the CD with instructions for the repair.
Apr 30, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
My tv attemps to turn on sound starts but when picture starts the system turns off.GE model d52gw12
This set shares the same chassis as some of the RCA models so More than likely a problem with the Horizontal deflection or the flyback transformer. Its not really something that the average person should take on and without the proper test equipment you could do more damage than good. But thats a starting point.
Aug 13, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
GE D52GW12 turns off shortly after being turned on.
that model is famous for bad flybacks. It uses flyback number 265409 you can get a replacement at the following link with free online tech support that will explain how to install the replacement. Here is the link.
http://servicemanuals.vstore.ca/
Aug 28, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
260 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
