Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Overheating Have had this tv for over 2 yrs now and this is the first time this message has come up. "T.V. is overheating." in the bottom left hand corner. I know it's self explanitory but it has never happened before and now it happens after about 15 - 30 min. Any ideas?
  • OttawaCanada Jul 05, 2008
    Thanks for the reply. I've had no internet for a while. The fan is working. I've noticed that the overheating only happens when it's hot outside. I just don't understand why that is a problem after 2 yrs.
  • OttawaCanada Jul 07, 2008
    Thanks for the reply. As long as it's not a serious problem I'll just keep the A\C on.
There are contacts inside the Livingstation that make contact with the heat sensor on the bulb. If you take the bulb out you will see them in the upper right corner of the bulb housing in the TV. These can become corroded resulting in a poor connection between the TV and the bulb. A poor connection will make the TV think it's over heating even if it's not. There are 3 contacts in the TV and 3 on the bulb. Clean these contacts with a lint free cloth and some alcohol on both the TV and the bulb, being careful not to let your fingers touch the bulb. If your hands are too big to reach inside the TV, rub a pencil's eraser over the contacts to clean them. When putting the bulb back into the TV, seat as firmly as possible, then tighten the upper right screw first.
Posted on Jan 06, 2010
  • daletriol Mar 17, 2011
    Thanks, this solution worked. Almost bought a new TV until I saw this post.
  • 4,234 Answers
There is a fan in the lower rear. Check to be sure that the pair path is clear and that the fan is spinning.
Dan
Posted on Jun 09, 2008
  • ABRsvcs Jul 07, 2008
    I would suspect the heat sensor transistor at this point. IT may be "noisy". Depending upon where the sensor actually is installed, the ambient heat may cause the circuit board to pull the sensor away from its heatsink causing premature detection and shutdown.
    Dan
I know you posted this over a year ago, but I also have a Epson Livingstation with the same problem. In the manual it mentions how important it is to clean the vent located on the lower left, back part of the t.v. You need to clean it about once a month it says in the Manual.
Lorenzo
Posted on Sep 25, 2009
Engine overheated , got second hand engine but still overheating after new Radiator and thermostat. What could be the problem
-Remove the thermostat and flush the engine back and forward couple time with water. Then re install the thermostat back to. Make sure the thermostat's spring or bottom go inside the engine.
-Make sure the water pump is in good shape, belt drive the water pump must be good tight.
-Try this you should be good to go.
Good luck
Mai Lor
Nov 04, 2014 | Cars & Trucks
My sa,sung tv hlt5075s is turning off by its self after a couple hours i read that it has a over heat problem. how do i fix it from overheating
They do have an overheating problem. It is serious and my husband solved the problem. I wish I could get this out to everyone on the internet. Behind the TV, on the left, is a cover over the lamp and color wheel. Remove it. Buy a SMAL
fan at Walmart for about $10 and set it there. Make sure it is running every time you turn your TV on. You will never have overheating problems again. Our TV Samsung would run for about an hour, then the color would washout. NEVER AGAIN. It is perfect.
Aug 31, 2011 | Samsung HL-T5076S 50 in. TV
Help! I'm stuck and stumped. 2001 Beetle GLS 2.0 - Two weeks ago the car was overheating quickly, red temperature light flashing and beeping. I changed the thermostat, flushed the radiator and filled it...
SOUND LIKE COOLANT FANS HAS A FAULTY THERMO SWITCH LOCATED AT THE BOTTOM OF THE RADIATOR ON LEFT HAND SIDE.CHECK THE FUSES 8 IN THE ENGINE COMPARTMENT AND CHECK FUSE 16 IN THE PASSENGER COMPARTMENT FUSE BOX.WHEN ENGINE OVERHEATING IF BOTH COOLING FANS WORKING.OVERHEATING PROBLEM COULD BE BLOWN HEAD GASKET.CHECK ENGINE OIL LOOKS LIKE MILK HEAD GASKET LEAKING.SEE WHEN YOU DRIVING LOW AND HIGH SPEEDS THE COOLING FANS SUPPOSE TO BE RUNNING.IF THEY NOT RUNNING THAT IS YOUR OVER HEATING PROBLEM.
Feb 02, 2011 | 2001 Volkswagen Beetle
1997 ford escort 2.0L engine is overheating. it has a radiator that is 3 yrs. old, a new head gasket, re-machine heads, water pump and timing belt that are 2 yrs. old, new thermostat and several radiator...
try this,wearing rubber gloves(cos its hot)undo the topmost hot hose clip and expell any air trapped.also use a hotwire to check
electric fan(s) if fitted.if they run it aint them.do they operate when idling and hot,if not then its the sensor.or if you have a viscous fan is that working.....when hot you will feel a resistance to turning by hand when the engine is stopped..another telltail that the thermostat is gone is,does the guage go down when you turn the fan on full heat for the interior??...cant think of anything else.....
Sep 15, 2010 | 1996 Ford Escort 4 Door
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Overheating... My temp light keeps coming on. I checked the oil and it is fine. Checked the radiator and it is full. Engine coolant bottle is full.... So what is making it overheat?
By the sound of it your light is telling you a lie and theres nothing wrong with the engine as if your not loosing any water and engine isent overheating then just get another sensor fitted.
But if you are loosing water or the engine is overheating ,then check the radiator with engine turned off,, put your hand on the top half of the core and then the bottom 1/2 of the rad core and if the top 1/2 is cold and the bottom is hot then you have either the thermostat is faulty or the radiator is dirty inside and maybe also out side in the fins.
Let me know how you get on . RON
Nov 24, 2009 | 1992 Buick LeSabre
Tv cuts off by it self. flashes message on bottom of screen check fan no. 2.
You haven't said which Samsung projector you have so I have to give you a generalised answer: The projector is overheating and going into protective mode.
Do as the message says: check the cooling fans as you won't know which one is fan no.2. Mostly it's simply the air filters which have clogged with dust and they're always easy to remove and clean. If you wash the filters they must be bone dry before you reinstall them.
Oct 15, 2009 | Samsung Televison & Video
Overheating
check filters and for blockage - poor air flow then will overheat
Aug 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Overheating
thermostat is on the left hand side of the cylinder head, with 2 bolts top and bottom holding the housing to the head,
Jul 08, 2008 | 1998 Honda CR-V
Overheating PowerBook G4 17" 1.67Ghz
If you have AppleCare and your PB is less than 3 yrs old, take it in- that seems abnormal. It's really strange that your PB was heating up while it was shut down. THat indicated that there is s/thing wrong with the shutdown mechanism. Make sure the machine is hsut down before closing the lid. Let it rest a minute.
Jun 11, 2007 | Apple PowerBook G4 Mac Notebook
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
321 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
