Question about Soleus KY-34 Portable Air Conditioner
Soleus LX-140 leaking problem
Our soleus LX-140 seems to be leaking leaving large puddles on the hardwood floor!!! It seems to be leaking from the bottom of the unit not sure if it is only from the drain located at the back bottom of the unit. It seems to do this regardless of the humidity. And according to the manual, if the water can not be exhausted fast enough the emergency tank should fill and the unit will shut off. Well, it is not shutting off. We are not sure how to fix this problem. Can you help?
  • 2 more comments
  • cengel Jun 13, 2008
    We have a Soleus PE3-09R-03 that is doing the exact same thing. It is extremely frustrating. We emptied the tank anyways-there wasn't much water in there. Any suggestions? Please help
  • Disco-Tech Jul 16, 2008
    My PE3-09R-03 is doing exactly the same thing, generating huge puddles of water from the bottom of the unit, regardless of cycle or humidity. I discovered the problem several weeks ago when I walked through a very soggy carpet and after cleaning and drying everything, installed a plastic catch pan. I generate at least a gallon or more a day and have to manually empty the pan when it gets close to fill. I DO NOT GET ONE DROP OF WATER FROM THE OVERFLOW AND THE UNIT DOES NOT SHUT DOWN because of that. I am getting quite disgusted that no-one from Soleus can be reached nor do I get replies from their "Service Dept.". I am
    fully charged now on this problem and will get serious about finding the answer.
    Ray
    sss
  • a_b_b Dec 27, 2008
    we are having same problem. according to the manual there is a rubber type knob thing thats supposed to go over the end of the drain plug.. that keeps the water from coming out... you remove this when you want to drain the unit... .. we have no rubber thing so its just continually draining itself, but i dont know how the knob got removed.
    so im looking for a knob but cant find any parts online yet
We have a 1-year PE3-09R-03 that just started dripping water on the floor. The red "tank full" light never came on. I opened it up to investigate, and I believe the problems are caused by dust. The plastic float that trips the "tank full" switch appears to have gotten stuck due to the combination of water and dust in the tray. Once I loosened it up and cleaned the guide tube it rides in, it would trip the switch when the tank was full. The reason the tank was filling up was a little less obvious. There is a 2-piece plastic tray that sits underneath the evaporator and above the condenser. The tray is supposed to distribute the water that's dripping from the cold evaporator coils onto the warm condenser coils so it can evaporate and be blown out with the warm exhaust air (note that "evaporator" and "condenser" are referring to the refrigerant - the terms appear backwards when referring to what's happening to the water on the outside). The tray and its lid have a series of tiny holes that were - guess what - plugged by dust. The tray is relatively easy to remove, just two screws and a spring clamp on the overflow hose. The tray lid is heat-staked onto the tray, you should be able to clean it without separating the lid. I cleaned and reinstalled the tray and verified that water would flow properly. I then reassembled the unit and fired it up, and it's been running without a puddle for over a day in humid weather.
The unit has a filter for the recirculating room air, but there is no filter for the outside air loop. Adding a filter would obviously help keep the dust out, but it could also reduce the cooling efficiency of the unit.
DO NOT use one of these on a floor you care about without some sort of emergency catch tray underneath!
Posted on Aug 17, 2009
I also have the same problem with my PE3, EXACTLY. I have installed a catch pan under the unit after drying out my carpet and am using the unit, but I have to empty the pan every few days. I suspect there is a connection problem allowing water to drain directly instead of being discharged out the venting. SOLEUS seems quite difficult to reach, but I am persistent and will find the answer. Good to know the problem is out there yet Soleus is not fessing up.
Posted on Jul 16, 2008
Where is the fuse located on my soleus air conditioner lx-140 house unit. I want to replace it.
PDF]download manual - SoleusAir
www.soleusair.com/Manuals/2013%20Manuals/.../PH4-13R-01_Manual...
Thank you for choosing a Soleus Air Portable Air Conditioner with Heat Pump ... owner's manual will provide you with valuable information necessary for the
Aug 17, 2015 | Soleus Heating & Cooling
How do I find an exploded view of a LX-140?
SOLEUS PORTABLE Parts Model LX 140 Sears PartsDirect
Sears has a diagram that if you click on it will expand it and you can pan around. If that isn't sufficient, you might try emailing the distributor directly: email to contact@soleusair.com
Jan 16, 2015 | Soleusair LX-140 14,000 BTU AC and 14,200...
Is a soleus lx-140 portable air conditioner good?
If it's a real good price, and you have enough technical skill to perform the much needed & required regular maintenance for operating (especially in dusty locations) or know someone capable of said task then I say it's worth it as a menopausal woman with constantly changing internal temperature. I bought mine refurbished from 3Gorillas.com (link below).
3Gorillas com Great Products Great Prices Free Shipping Every Day
If you're not technically savvy then they may have a different model for you, but I did my research. They definitely have the best prices for appliances.
~cheers
Jun 22, 2014 | Soleus LX-140 Portable Air Conditioner
My braker keeps tripping with only the tv on and electronics that barely use a lot of juice. it doesn't seem like it pumping out enough cool air for 14,000 btu's either
14,000 btu is a very large unit it should be on a dedicated cuircut of either 15 or 20 amps all by itself.check the rating plate for correct amperage
Jul 21, 2011 | Soleus LX-140 Portable Air Conditioner
Have a Soleus LX-140 portable air conditioner. Water was leaking out the right side of the machine. Opened the casing and found a clear hose, one end attached to the plastic tray above the condenser and...
I have an LX-100, and had the same problem, so I am guessing that the designs are similar. There should be a pump in the condensate pan at the bottom of the unit -- on mine, it was near the front, right next to the overflow float switch. There should be an outlet on top of the pump, which is where the hose needs to be attached.
It looks like the pump pushes condensate up into that plastic tray, which lets if flow over the heat exchanger, both cooling it and evaporating the water. With the hose detached, you're probably noticing degraded cooling performance and a lot more condensate in the holding tank than there should be. At least, that was the case for me. Good luck.
Jul 05, 2011 | Soleus LX-140 Portable Air Conditioner
Cannot turn on.
Since you have power to the clock display- there is power to the unit. The "power" function button has failed because the momentary switch on the circuit board below the touch pad has failed. These little push switches have a short service life.
I suggest checking a source who sells the control circuit board for Soleus Air LX-140. Might be similiar component.
KT
Jul 30, 2010 | Soleus LX-120 Air Conditioner
Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
Jun 17, 2010 | Soleus LX-140 Portable Air Conditioner
Soleus air heat pump soleus lx 140 quit working
Hi
The Soleus Air condenser blower wheel is all plastic and I have seen many of them disintegrate from normal residential use. It's just a weak part.
Go to shop.soleusparts.com and buy a metal blower wheel replacement kit. Problem solved!
May 19, 2009 | Soleus LX-140 Portable Air Conditioner
Soleus Heat/Air/Dehumidfer Unit
I have had a soleus wall unit since 2005.
It is a wall unit in my apt...I have never had to use the heating part...but use the cooler part alot.
I can not figure out if that lil raindropis for adding moisture to a room...or is it to remove moisture from the room?
My apt always has to much humidity, so I do use that setting quite often, but can't tell any difference in the humidity gage.
Who knows anything about using one of these.
Sep 02, 2007 | Soleus KY-34 Portable Air Conditioner
Soleus KY-34 Portable Air Conditioner Logo
2,297 people viewed this question
Top Soleus Heating & Cooling Experts
Chris Hall
Chris Hall
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
