Question about SAMTRON 55V 15" CRT Monitor
Control lock a pop up named control lock is always being displayed on the screen also adjustment menu of my moniter displays the same popup when i press the menu button please suggest a solution to this..I will be very thankful please mail the solution to karchan33@gmail.com thank u
  • 37 Answers
Temporarily you can -- hold down, while monitor is on and the menu button for 10 seconds (source Samsung faq). This hould unlock the buttons.
This problem is due to abad 7805 regulator ic ora memmory ic
To completely stop this you will have to replace the 5 v regulator
Posted on Jun 09, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Contrast menu keeps popping up in my moniter,it is a hcl moniter,the menu is not the normal adjustment menu that appears in the moniter which has all options like colour,brighteness etc.its just like a...
mmm look you have a setting problem reset the screen to it's defulat if it didn't solve the problem you will have to change the press bottoms and you will need some who know electronics to help you with the board but first try to rest it to the defulat settings
Nov 15, 2009 | ViewSonic VA721 17" LCD Monitor
Image on monitor is stretched
if you have recently added the moniter to your pc then go to microsoft windows updates and run the custom updates and under hardware on the right there should be a download drive stating the name of your moniter and download it,,,unless you have not set the resolution in the control panel after pressing start and go to moniter display to adjust the slider to the right setting,good luck
Nov 10, 2009 | Computers & Internet
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Onscreen Display is always ON
usually this is controlled from a small separate board you can find them on ebay for about 20 dollars.
Jun 22, 2008 | Samsung 793S 17" CRT Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Moniter problem
you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows.
Sep 16, 2007 | Computers & Internet
SAMTRON 55V 15" CRT Monitor Logo
108 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
