Question about Pioneer VSX-D308 Receiver
Pioneer VSX-D308 Receiver Problem
I have 2 speakers hooked into the main L & R outputs and 2 in the Surround outputs but I cannot get the Surround speakers to play. When I press the speaker select I get "A" or nothing else. Am I missing something here?
Go through your mode channels to put it on surround sound
Posted on Oct 14, 2008
How to adjust front speaker level on vsx-d308 pioneer surround sound ?
Did you use to be able to turn up the front levels and now you can't?
Or is it the first time you have installed it?
If it previously did then clearly there is a fault.
However if not. Then like many receivers the front volume is simply controlled by the main volume control. If this is the case then you need to adjust the other channels to give you the best sound. The best way to do this is get one of those THX DVD discs. On the menu to the disc you will find a setting for setting up the sound THX screen. It will produce a test tone for each speaker. You then adjust it for the best sound quality. This way the sound field will sound great for your living room and Dolby movies will have you jumping out of your seat when an unexpected sound appears on the left channel and voices won't get drowned out by noises from the back.
Apr 23, 2015 | Pioneer VSX-D308 Receiver
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
I have a Pioneer VSX-D308 reciever and I have a EQ. How do I hook it up to this reciever?
I only know of one way to do this and here it is:
1. Plug your tape deck's output (cassette or R2R) into the EQ's "Line In".
2. Plug the EQ's "Line Out" into the Receiver's "Tape 1 Input".
3. Now plug the Receivers "Tape 1 Output" into the Tape Player's "Line In".
4. You have now made an "FX loop" for the Tape Deck. Now you just have to put the Tape Deck on "Tape Monitor".....put the Receiver on "FM"..... and turn on your favorite FM station and you will hear the FM Receiver THROUGH the tape deck's "Monitor Send" AND the EQ.............set EQ to taste....... and BINGO.......DONE!
Enjoy,
SKYNETRP
Jun 09, 2011 | Pioneer VSX-D308 Receiver
Is it possible to hook up a powered subwoofer to this unit? It has a centre pre-out, but nothing labelled for a sub, and the manual is useless. This is a very nice old receiver, works perfectly, and I'm...
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSXD903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
(To the guy [dunnbiker] that says there's no rear channels: You're wrong.) The VSX-D903S has 2 stereo (A/B) channels, dual center channel (place center speakers to the left and right, or above and below the screen), and two rear satellite channels. It is a 3-Ch Logic/Dolby Pro-Logic Surround equipped receiver, not a DolbyDigital/DTS multichannel x.1 surround unit.
Dec 19, 2010 | Pioneer VSX-D903S Receiver
My Pioneer vsx-d308 keeps giving me an "overload" message and will not work
Do you guys know how to turn up front speakers on this amp????
Sep 02, 2010 | Pioneer VSX-D308 Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
May 26, 2008 | Pioneer VSX-D308 Receiver
Pioneer VSX-D308 Receiver Logo
435 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
