Loss of color after lightning storm
After a flash of lightning last night I lost all red tones on my TV, everything is just blue and green. The power never went out just the color on the TV and I have tried resetting the color on the menu to no avail.
Is there a way to fix this? I have tried using a small magnet on the screen and it does bring back the color to that area but only as long as the magnet is held there.
    Scholar:
  • 68 Answers
In tradition televisions, each color has its own gun, convergence and control circuit. One or more of these are most likely bad. Repairs on standard CRT TVs nowadays are usually cost prohibitive.
Posted on Jun 09, 2008
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Sony Bravia KDL 40 HD
it's in a service test mode. have you unplugged the tv? that should reset the tv..if you still have problems after ..it will need repair.
Sep 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Blue pincushion
Shannon you have a blue convergence failure. this problem can be repaired in home, by a good tv repair guy. John
Sep 11, 2007 | Sony KP-51HW40 51" Rear Projection...
DVD player not working right
Check your cables between your DVD player and the TV, this play has component video outputs that could possibly cause this issue.
Dec 25, 2006 | Sony DVP-NC600 Multi-disc DVD Player
Problems with green convergence
Very common problem John with projection sets. They have High powered audio amps inside the sets to control the red,green, and blue convergence for the color alighnment on the screen. These amps blow out and should be replace all at one time. There are also resistors that can go out at the same time and your gonna have to have these replace also if they have any discoloration to them. This is not a job for the novice to attempt, as there are HI Voltage safety issues involved, and should be done by a trained tech. This repair should run you anywhere from $250.00 all the way up to $400.00 bucks, depending on where you live and who you get to repair the set. It's always better, in my opiniuon to call a factory authourized repair place as they should have all the service data and most parts for your set. Good Luck
Jul 23, 2006 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
