Question about Gateway GT5028 PC Desktop
No display on LCD monitor
Unit powers on, fans and hard drive responds but no display, ellow led for hard drive stays on for about 30 sec then goes out,monitor checks ok separately. 5v&12v are ok on hard drive. This is a all in one motherboard, 6100 Nvidia.
  • 1 more comment
  • BD01 Jun 27, 2008
    After powering unit off and disconnecting battery & waiting two min's, no help, same result. Also after removing and reinstalling CPU same result as well. Appears not to boot up at all, even though you can hear the hard drive spinning up in the beginning. LED for hard drive comes on solid for about 20 to 30 sec's and then goes out, still no response from the monitor except when unit initially powers on. The monitor shows it's own internal self test message only at the time when the computer is powered on then goes back off again within a few moments. It has tested fine on another computer.
  • emiliorobert Jul 15, 2008
  • Anonymous Nov 30, 2008
    i want to test a monitor wihtout it been connected to the cpu.how possible will this be? what pins can i connect to acheive this?
    Scholar:
  • 107 Answers
Hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
Posted on Jun 10, 2008
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
The usual problem with connecting a flat screen after you have used CRT's is that your resolution is to high for the flat screen-connecting it to another screen and bringing your resolution down to 640x480 and then connecting your flat ,most of the time sorts out your problem.You can then try to up your resolution to a workable resolution.1024x768 works fine.Regards
Acer Aspire 5610 wont start
Trying doing a Hardreset
Remove the adaptor and Battery and press the Power for about 30 secs
Dec 21, 2013 | Acer Aspire 5610-4648 Notebook
How do i fix my LCD?
I have got a hp pavilion dv5000, when I turn on it the screen goes blank.
Power led glows, I hear for a few time the fan, disk led flashes intermittently and also I feel that the DVD player tries to load.
If I try to click on caps lock or num lock, leds don't respond to commands. I tried the hard reset pressing the power button for 30 seconds with the battery and the power removed. Nothing to be done by connecting an external monitor....
Thank you
Jun 11, 2013 | HP Pavilion dv1000 Notebook
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Acer 5610 cracked LCD..tried hooking it up to a external monitor, but all it does is Pwr up..no dispaly on external....fan goes on for about 30 sec. 3 led light up and stay on (pwr button, pwr indicator...
You may have to unplug the cracked display from the motherboard first before using the external display.Also check in the bios and make sure its set to CRT or for external display.If the keyboard has a key for switching displays try it with the FN key pressed.If that doesn't work you may have a damaged video card.
Oct 04, 2010 | Acer Aspire One PC Notebook
Monitor goes dark 2-3 sec after power up, green lite stays on
Look for shorted out transistors (four, c5706/5707) in the inverter backlight transformer driving circuits.
Jan 21, 2010 | Dell E153FP 15" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
No display
hi ,
Display will come
Jun 10, 2008 | Gateway GT5028 PC Desktop
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Gateway GT5028 PC Desktop Logo
334 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
