Question about HP PSC 1210 All-In-One InkJet Printer
Paper won't feed
The paper won't load from the tray. the printer seems to respond and i hear all the normal noises, but the paper doesn't move. it was printing fine, and then in between jobs it just stopped.
  • rahimsheikh Jun 13, 2008
    Paper does not feed the printer, alle the normal noises are heard, but no printing. error message says, paper is jammed. please help. Ho 1215 psc all-in-one
  • Anonymous Jun 26, 2008
    It makes noises like it is going to feed but some of the noise is just like wheels spinning. But it won't feed the paper.
  • 181 Answers
You need to clean the rollers in the back panel of the printer and reset the cradle or carriage if you can. The cradle is what moves the cartridges back and forth inside the printer.
Unplug the printer while it is powered on and remove the back panel. Get a damp cloth (not too wet) and wipe off the rubber rollers in the printer as well as on the panel. Replace the panel and Open front panel where cartridges are and move them all the way to the left and back again to the right.
Make sure there is no paper or anything in the way blocking the printer from printing. Plug printer back in and it should come on by itself and initialize.Print a page from your computer. It should now only feed a single sheet at a time and the cradle
should move freely.
If not then the paper sensor isn't working correctly and you will need to replace the unit if that is the case. You should call and see if you can repair or upgrade the unit at a discounted
price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Posted on Aug 07, 2008
Sharp AR-205 misfeeds at transport area from both paper trays and bypass tray both. Tested using different paper in all trays and still won't feed in at the transport area. The paper just pleats up...
it means the drum is not moving check it, insert it properly. or therre is a broken gear somewhere or the motor that makes the drum to rotate is not working properly. The registration sensor not working or not postioned properly.
Aug 01, 2011 | Sharp Office Equipment & Supplies
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
Always paper jam. need solution
hello, the first thing i would recommend you to do is listen to machine, if you hear the machine clicking, the sound is rythmic, sorry, it does not carry a beat, but the noise is not normal, if you do hear the noise then yes your printer is broken. if you have lower tray, check to see if your jamming from that tray, you can clean both feed rollers for both trays, and try again, if document feed jam, check to see if something tore in the paper guide.
Sep 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Hp l7590b no paper load
hi friend,
Step 1Turn on your printer. Make sure it is plugged into an electrical outlet and installed properly.
  • Step 2Wait for your printer to stop. Do not load paper while it is printing or running any kind of maintenance operation.
  • Step 3Prepare your paper. Make sure your paper is right side up (glossy, whiter or label side should be facing up). Make sure all the pages are lined up together, like a deck of cards.
  • Step 4Locate your paper tray. Some printers have a manual tray and an automatic feed tray. Refer to your printer’s documentation to find the automatic feed paper tray.
  • Step 5Place your paper in the tray. For 8.5 by 11 inch (standard) paper make sure the 8.5 inch side will be fed into the printer.
  • Step 6Set the paper guide. This is the movable piece on the side of your paper tray. One side should move and the other should not. Move your paper so it touches the side that does not move, and slide the paper guide so it touches the other side. Some paper guides have markings so you can set it to the exact measurements if you know the size of your paper.
  • Step 7Set the paper thickness lever. Refer to your manual to determine which setting this lever should be at. Generally, standard paper does not need a different setting and special media like glossy photo paper or envelopes should use a thicker setting. You can usually access this lever the same way you access your ink cartridges.
  • Step 8Let your printer know what it is printing. If you are using a special media, then set the options before you print. Click “Properties” on the print dialog before you print something. From there, change your media type to whatever kind of paper you loaded.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Fan your paper back and forth before lining it up to load into your printer. This prevents static build up which is the leading cause of paper jams.
    • If your printer doesn’t feed the paper correctly at first, try making slight adjustments as it tries to feed to find the right spot.
    • Refer to your manual for in-depth paper loading instructions.
    • Many printers have a resume/cancel button. This is to be used when you need to load paper mid-print job.
    • Do not overload your printer.
    • Avoid non-standard media types such as loose leaf paper with holes or folded or wrinkled paper or anything with affixed stamps or stickers. These can jam your printer.
    hope this helps u
    please rate me...........................
    thak u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
    The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
    Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
    Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
    Nov 11, 2009 | Brother HL 1440 Laser Printer
    Mp780 - Paper attempts to feed and fails Message: Load paper
    Your paper feed source is wrong .Go to the printers control panel and change the feed source.
    If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
    Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Paper not feeding properly, nothing jammed as I have checked. Loading tray having problems.
    Check to see if the printer is actively trying to feed the paper. If you hear it trying to feed and see the wheels turning, but the paper won't feed, check to see if a screw securing the feed wheel has come loose. If you hear the sound, but nothing moves to pull the paper in, then you probably have a bad printer. They're too cheap to replace to bother fixing - so get a new one.
    May 25, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
    HP PSC 1315 Problem
    Glad to know that your problem is solved.
    Thank you for using fixya..
    Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Load Noises
    If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
    If the noise does not recur with the print cartridge removed, replace the print cartridge.
    If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
    http://www.hp.com/support .
    Feb 15, 2008 | HP LaserJet 1320 Printer
    HP PSC 1210 All-In-One InkJet Printer Logo
    178 people viewed this question
    Seeker5211
    Seeker5211
