Question about Insignia IS-LCDTV32 32 in. Television
Won't power up
This tv just decided not to come on either with power on tv or with remote
  • 6 more comments
  • Anonymous Jun 10, 2008
    the tv will not power on either through the on/off button remote or cable box remote.
  • sandieb Jun 14, 2008
    My t.v. won't power up...it tries to come on, then goes off, over and over and over until it blows the circuit breaker in my home. Could this be a fire hazard???
  • regrog13 Jun 16, 2008
    My t.v. also won't turn on. It tries a couple of times but never has a picture. For a week or so we could unplug it for a couple of minutes and it would be okay, but last night and today it won't go on at all.
  • oldirtybahen Jun 18, 2008
    My tv won't turn on. It will turn blue as if it is coming on but will not stay there for more than a second or 2. It started a few days ago but eventually worked and now i can not get it turn on at all.
  • mnagy513 Jul 07, 2008
    I have had a Insignia 27 inch LCD TV for about 13 or 14 months now. It has worked fine until the last week or so, now when I turn it on with the remote or the button on the TV it will start to turn on, the blue power light will go on but the screen will remain in the black screen as if it was about to finally go on. This had happened maybe once or twice in the last week but those times it worked fine but one night I turned it off, had dinner and returned to it not being able to turn on, I have removed and re-plugged every cord....... any help would be much appreciated......
  • Anonymous Jul 12, 2008
    wont power up. Blue light at logo lights but tv screen is black. This set is less than 2 years old
  • lostgeek Jul 17, 2008
    looks like this TV is a total bust from everyone's comments. Mine waited until about 1 month past the warranty and then simply wouldn't turn on. Does anyone have a solution that doesn't involve having an engineering degree?
  • Anonymous Aug 06, 2008
    TV will not turn on.
  • 2,326 Answers
It seems like there are power failures on these LCD as well. Sometimes it could be an easy fix as stated by IMRoach but is some cases is not or the failure is in a different assembly. In about 95% is the power supply that failed.
If you require further info you can write to jah2mil@hotmail.com
Posted on Jul 17, 2008
MY TV died over a year ago and for some strange reason I never got rid of it. I recently (today) replaced two capacitors and it works great again! It wasn't difficult to solder them on- and this was the first time I've touched a soldering iron. Open the back... you will see which capicitors are bad because they will be swollen. I ordered new capicitors online (Radio Shack didn't carry them). Just make sure that you solder them on in the right direction. The first time I tried the capicitor immediatley blew, the TV started smoking, and it left the room smelling of funk for a few hours.
Posted on Jun 12, 2008
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
The remote for my Philips 47PFL7403D/F7 TV will only function if I hold it about 2 or 3 feet from the TV. Sometimes, it won't work at all. This is getting VERY frustrating! I have replaced the...
Good day!!!!!
That problem is usually cause of weak infrared on your remote..It is not totally defective but the capability of infrared is not enough than the normal...
You need to replaced first the infrared before you decide to junk it..It is look like L.E.D that place on the top of the remote..
You can also read this tip on how to repair remote control:
http://www.fixya.com/support/r9401195-fix_remote
I hope this solution will be helpful..
Thanks for using fixya...
Aug 10, 2011 | Philips 47PFL7403D 47 in. LCD TV
I have a Technika 24in tv / dvd. The remote works fine except some of the buttons do not perform the desired function. i.e. the dvd menu button does not bring up the dvd main menu but a system screen. I...
Hi
The software version decides the function that coincide with remote signal. If the remotes' infrared signal frequency differ to the receiving spctrrum of the software, it won't work well. You must have the remote of the present TV itsef to work in coincide with the button actions. Just get it. There is no other way. OK.
Jul 15, 2011 | Televison & Video
TV won't turn on with remote or manual, and standby timer light flashes
The flashing timer light blinks out a code, where it flashes some number of times, pauses, then repeats. The code indicates what fault is keeping the set from coming on. Unfortunately, all the codes tend to mean that there is some electronic problem with the TV. Unless you have some electronic servicing skills and the necessary equipment to troubleshoot the problem, you'll need to have set checked by a professional. For any code there can be many causes, so I can't offer any other advice.
This might be a good time to check sale prices on LCD sets. Let a technician check the set and give an estimate for the repair, then decide.
Jun 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
3.4 IR Dish Network remote control codes for a Prima TV/DVD combo. I can't seem to find any codes that work for either.
I'msorry I did also attempt to locate a Prima remote code within DISH Network's database aswell but unfortunately I was unsuccessful and have found no remote codesfor the TV you have. However, we can still attempt to program the DISH Networkremote to the Prima television without a remote code, this would be done bycompleting a Power scan. If you decide you would like to program the DISHNetwork remote to your TV using the power scan, I have included instructionsbelow to further assist you. Withthe desired equipment on, press and hold the correct Mode button (In this casethe mode button will be "TV") until all the other mode button back lightsilluminate, then release. 1. Pressand release the Power button. 2. Pressthe Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, theequipment will power off. 3. Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
After successfully completing the power scan to program the DISHNetwork remote to your T.V the remote should now control your TV. I hopethis helped! Please feel free to let me know if you have any other questions orneed additional help. -Kirstie DISHNetwork
Jan 30, 2011 | DISH Network IR Remote Control
My sharp tv wont turn on
I don't know if you have this problem but I had a similar problem aswell. My TV remote and my universal remote wouldn't turn on or perform any of the funtions as they should. This is what I did to fix it: 1. unplug the TV from the power outlet. 2. take the batteries out of your TV remote. 3. press the power button on the TV remote, and then press every other single button one by one from left to right (as if you were reading a book). 4. plug the power cord back in the power outlet. 5. replace the batteries in your TV remote. 6. try turning on the TV using the factory remote.
These steps, as weird as they sound, worked just fine for me. My TV is now responding to my remote and my cable remote is able to control the TV again. No, I did not loose the universal (cable) remote's TV codes. FYI. the steps mentioned above were performed using the TV native remote (factory remote). Hope this will work out for you as well. And if you are wondering how I knew this would work, well I saw the same steps on another website (sorry I can't remember which website it was) and decided to give it a try before I took the TV back to BestBuy for warranty repair...which would have taken like two weeks.
Jan 01, 2009 | Proscan PS27500 27" TV
Westinghouse LTV-27w6 27 in. HDTV LCD
Have you unplugged the set from AC power? Not just 'turn it off' but physically remove the power cord for 1 minute. Often this 'resets' internal circuitry when a 'power off' will not.
May 14, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Insignia IS-LCDTV32 32 in. Television Logo
134 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
