Question about Minolta magicolor 2300W Laser Printer
How do you change the drum cartridge ?on a 2300 qms minolta printer
  • Anonymous Jun 10, 2008
    how do you change the drum cartridge
  • rh0ndak Jul 24, 2008
    there is no unlock lever. I just reach in and pull the cartridge out. There is not a thing holding into position....... The blue is the only cartridge showing...but I cannot get the pink or yellow into position to pull them out.
  • 300 Answers
Replacement of the OPC Drum Cartridge
1. Open the Front Door.
2. Remove the Waste Toner Bottle.
3. Lower the unlock lever and remove the Drum
Cartridge.
4. Reinstall the new Drum Cartridge
5. Pull the protective sheet of the Drum Cartridge to
the front and remove it.
6. Raise the unlock lever.
Posted on Jun 11, 2008
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
May 25, 2009 | Minolta magicolor 2400W Laser Printer
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Need Override for Low Toner Message Minolta QMS 2300
It depends on the model. The 2300 series using a mechanical mirror on the cartridge itself. A tab needs to be moved the mirror slid back to home. The 2400 series & newer uses an IC that you need to replace. when you buy your toner to refill the cartridge make sure you get the IC with it. Russell
Aug 21, 2008 | Minolta magicolor 2350 Laser Printer
Konica minolta qms pagepro 1250w
Looks like your drum cartridge is dirty / busted. 1710400. e-bay has some new cheap drum replacements for about 40$
Feb 25, 2008 | Minolta PagePro 1250W Laser Printer
Minolta-qms 2300 DL
open the front door, remove the waste toner bottle then remove the drum. turn it upsidedown and you'll see 2 metallic covers hiding the fuser. you can remove one of those covers very easy and replace the fuse
Jan 01, 2008 | Minolta magicolor 2350 Laser Printer
Cartridge Removal 2300DL QMS Minolta
magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Nov 26, 2007 | Konica Minolta magicolor 2300DL Laser...
Random lines printed on extreme right side of page
i had that happen when toner leaked out and got all over the place...try cleaning up any stray toner [even in the places they tell you not to]
Nov 24, 2007 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300DL Printer - black streaks
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Minolta magicolor 2300W Laser Printer Logo
203 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
