Question about Singer 3116 Simple
Singer Simple 3116
I just purchased this sewing machine last night and now it is jammed. There is no thread in it at all - not any around the bobbin area that I can see. I have tried to oil it and that has not helped. The handwheel will only turn partially forward, and it will turn backwards. When I called Singer they recommended that I take it back to the store and exchange it. When I called another repair shop they informed me that the Singer Simples have a lot of problems. Can you help me fix this or should I just eat the gas costs and return it (I live out in the country so it's 30 minutes to get anywhere).
Thank you!
  • Jfrogs Jun 09, 2008
    There is no thread in the bobbin holder. There are no screws holding the bobbin holder in place. Thanks for the try though... any other advice?
  • Jfrogs Jun 10, 2008
    There was no thread in the machine. So the problem did not pertain to thread. I decided to just return the machine. At the store, the display model was broken in the same manner - I believe this is a common problem with Singers. I purchased a Brother instead and have been sewing away with no problems.
Your problem is a simple one.Jamming is due to thread getting trapped on the bobbin holder.All you need to do is to unscrew two screws holding the the bobbin holder clean the same and reasseble it.your problem will be solved.N.Govindarajan
Posted on Jun 09, 2008
    Problem Solver:
  • 26 Answers
Jamming is due to loose needle thread.
Make sure that your threading is correct.
What I mean is:
1.Lift the presser food up.
2.From the thread spool, pull the needle thread inside the tension discs.
3. Pass the thread under the thread takeup spring.
4. go up and pass the thread through the eyelet of the thread takeup lever,
5.Go down and pass the thread in the thread guide above the needle,
6. Pass the thread through the needle eye.
7. Pull out 6-7cm of thread out of the needle eye.
8. Your bobbin case must be in position.
9. Turn the handwheel a whole turn,towards you by hand, holding the end of the needle thread with your hand.
10. the needle will go all the way down and then rises up out of the needle hole plate, and the bobbin thread will come up.
Push both treads backwards
11.Put two plies of material under the presser foot.
12.Release the presser foot. (the needle thread discs now are close).
Make a sewing test, and adjust your threads so they meet inside the two plies of the material.
Use two diferent color threads for testing.
If you see the lower thread, on top of the meterial,
either your lower (bobbin)thread is loose, OR your needle thread is too titght.
If you see your needle thread under the material,
either your needle thread is loose OR your bobbin thread is tight.
In both cases you must adjust the thread tensions accordingly.
13.This VERY IMPORTANT. Not only the needle must be up before start sewing. THE THREAD TAKEUP LEVER MUST BE ALSO AT THE UPPER POSITION.
14.Before removing the material from the machine.
a) Turn the machine by hand Until the needle is outside the material,
b) The thread takeup lever is at its upper position,
c) Lift the presser foot,
d) Remove the material backwards (away from you),
e).Cut the threads 6-7cm long.
Now your machine is ready for the next cycle.
These are basic instructions for all single needle sewing machines, all brands and all models
Posted on Jun 10, 2008
Threading the top of model 3116 correctly
here's a link for a free manual
http://www.singerco.com/uploads/download/438_3116.pdf
try changing the needle
make sure the thread does not come off the thread take up lever
make sure the bobbin is not over full
make sure the bobbin is turned the right way in the bobbin case
cause that can make the sewing machine jam up
clean under the needle plate & in the bobbin area for lint
Oct 04, 2012 | Singer 3116 Simple
I have 3116 singer machine, the stich is not grabing the bobbin thred and it is making a knots in the back of the fabric what should i do?
Bobbin thread is backwards.Turn the thread around before inserting it into bobbin locaction.It MUST be put in correctley or this problem will never stop.Check your threading Bobbin Instruction CLOSLEY,I found this out the hard way too.Good Luck.
Dec 05, 2011 | Singer 3116 Simple
The needle on my sewing machine won't budge with the side know or the foot pedal.
Sounds to me as though you have a thread jam. Take the bobbin out and look for thread ends or thread wrapped around places where it shouldn't be.
Feb 08, 2011 | Singer 3116 Simple
I have a singer simple 3116 sewing machine and it stitches loose upper threads. I?ve tried adjusting the tension, re threading, flipping the bobbin around, and even different fabric. But nothing seems to...
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
Dec 27, 2010 | Singer 3116 Simple
I was sewing last night an all of a sudden it just stop working i let it cool for 20 min and nothing what do i do could it be the moter it is a singer simple 3116
There is probably lint or thread caught in the bobbin area and causing it to overheat. Call Singer at 1-800-4singer and they can advise you,
May 13, 2010 | Singer 3116 Simple
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
Singer simple 3116 jams up every few inches
Use a SA 156 metal bobbin (buy on ebay 20 for $8.99 and free shipping) and double check your threading. Refer to your manual
Mar 18, 2009 | Singer 3116 Simple
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Singer simple sew machine
Read your manual, then watch the excellent video. If you can't find your manual go to Singer.com and download one for free.
Aug 29, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
560 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
