Question about GE Refrigerators
How can I convert 110v ge frigde to 220v single phase electrical input? I am moving to Vietnam and they use 220v single phase electricity for househose appliances? Please let me know if this is possible. Thanks
  • 958 Answers
Yeah...buy a step down transformer there in vietnam...im sure they have some there. try to buy the one best suited for your refrigerator in terms of capacity rating. if your ref is big, then buy a big transformer. dont use any type of step down transformer.
Posted on Jun 09, 2008
Wiring a ge motor 220; has three black wires
That's a 3 phase motor(ph3). And probably a 220v/460v? Or a 110v/220v, BIG difference! You'll need to figure out your supply voltage and wire it accordingly. Normally, if 220/460, all 3 black wires are hot legs, and this is probably what you have, because 110v will normally have higher amperage than what you posted. And if the motor runs backwards, switch any leg with 1 other. Hope this helps!
Aug 19, 2017 | GE Heating & Cooling
Solis 365 royal hair vac I was wondering if it was possible to use this product in australia due to the voltage difference and if there is a product made to suit australian voltage or if an adaptor...
There are products called Step Up transformers/Step Down (Voltage Converters) that can be used. We use these For our 220VAC Australian manufactured lasers when we need to run them in a Dr.'s office that only has US 110VAC.
Info from a website:
Electrical voltage in USA is 110 voltwhereas; the voltage in most of the foreign countries is 220V to 240 volt. A voltage converter / transformer, also known as power converter are usedto convert electricity coming out of the wall to match the voltage of yourdevice. These Voltage transformers or converters can be used safely withRefrigerators, Microwaves, Juicers, Blenders, Coffee makers, Power Tools,Stereo Systems, TV's, Video Games, DVDs, Hair dryers, Chargers, computersand other electronics when travelling abroad..
Remember to leave at least a 100-percent margin for power surges/spikewhen buying a transformer. Some items, such as Televisions, computermonitors spike when you turn them on. For these products you need to buy avoltage converter transformer that is at least 3 times the items capacity.Power tools, laser printers and heating appliances like coffee makers,toasters, microwaves, Halogen, Fluorescent bulbs you must leave a marginof 3-4 times.
Voltage transformers are made to convert single phase 110 or 220 volt.American 220 Volt consists of 2 phase of 110 Volt and European 220 Voltconsists of 1 phase of 220 volt.
Volts x Amps = Watts (i.e. 110V x 0.5 AMPS = 55W). Please make sure not torun any appliance with higher wattage then voltage transformer's wattage.This might damage both: your appliance and the transformer!
I hope this helps.
PHmaddnes Transformer Purchase Guide
May 06, 2014 | Cell Phones
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at--- http://americanrotary.com/static-phase-converters.html
Jul 24, 2010 | Electric 1HP Century Single Phase Extra...
110v stuff works, 220v stuff doesn't
Check and make sure you have the phasing correct on your wiring. If you have both hot wires connected to the same phase in your breaker panel than you will only get 110 volts. Also check and make sure your fuses are all good. Just take a multimeter and check the voltage across the two hot wires, if you get 110 then test each hot to ground if you get 110 at both than the phasing is incorrect, if you only get one side 110v than you have a fuse or breaker or something not connected problem. In-case your not sure on what i mean about phasing, Your power from outside comes into your panel at 220v from two different lines each at a different "phase" from each other. Google would be your best bet on learning this topic, Since I am not gonna get into electrical studies here :-) Generally in your panel every second breaker slot is the same phase, so if you you need two in a row on the same side. If all that is correct than there is something wrong with the stove. Check fuse's mostly, other than that you will probably need a professional. Unless your good at reading schematics.
Please post back with your results and please vote if I have helped you in anyway.
Dan
May 22, 2010 | Amana ACF4215 Electric Kitchen Range
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Using dryer in 220volt country
Bombay is 240v single phase, the three wires in the socket are active neutral and earth, not as the 2*110v90degree two phase American circuit active1 active2 and neutral
If the transformer is designed for American use, it does not step down 220v,
it instead takes a 2*110v90degree 2 phase supply and produces a high current 110v single phase output, by setting both input phases electrically 90degrees apart on a common primary winding.
This is not compatible.
replace the dryer, cheaper faster safer
should have left in Houston
Sep 09, 2008 | Kenmore 62602 Electric Dryer
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
