Question about Maytag Atlantis MAV6000 Top Load Washer
Old Maytag washer LA182 motor replacement
26 year old maytag washer. Repalcing the electric motor.
New replacement maytag motor has jumper. The wires are wht, red, yel, blk, and blue. Old motor has wht, red, yel, blk, and green.wires
Is the blue wire now go to the old green wire ?
Maytag has confirmed that this new motor is the correct replacement & updated model for my washer.
Part number of the new motor is 12002351 single speed motor.
Maytag has been no help at all for the questions of the wiring difference., Local shops have been no help.
HELP !
Neil in AZ
  • Anonymous Apr 01, 2014
    I pulled the wires off the motor switch from motor to switch on a512 maytag washer dont know they go back
There was no wiring diagram with the new motor. I did so more testing and found the old green wire now goes to the new blue wire. It is the spray and spin cycle.
Sure would have been nice if Maytag was more helpful. One little note in the directions is all that would have been required....
Thx,
Neil
Posted on Jun 23, 2008
    Problem Solver:
  • 5 Answers
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
My timer will not advance.
Normally that is a timer motor or motor gear and needs a new timer. Easy replacement, just unplug the washer, take the back off and replace one wire at a time from the old to the new. Then remove the old one and mount the new one. I had to replace mine a while back.
Mar 20, 2016 | Maytag Washing Machines
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
My dryer bips Problem with the Maytag Neptune MDE5500AZW, SER N 73252332JX Electric Dryer. It bips all the time. Some times don't want to start. Please let me know what is the problem. Thanks! Reema...
Mine does the same thing (it's doing it right now!). I had it looked at and they said I have to replace the mother board. It's going to cost me $300! It stops beeping and works normally most of the time. When the house is humid, it starts beeping again.
Maytag is total garbage. Our Maytag fridge had to have a new compressor installed after only a few years. Our washer and dryer are only a few years old as well. Never buying Maytag again.
Jan 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
Motor failure on year old Maytag washer
these washers have a defective motor right from the box, yell louder.
Dec 04, 2009 | Cars & Trucks
Maytag Washer model LA182 loud while washing.
there should be a belt tensioner on thebelt path check to be sure the belt is not slipping
Aug 14, 2009 | Kenmore 44102 Front Load Washer
Maytag top load washer growls like its skipping teeth/gears while agitating.
Hello tomlyoung59
it sounds like the coupling between the transmission and the agitator is bad . You know the transmissions now a days have plastic gears in them and if you continue to use it may blow the transmission!
Speed queen is the only one I know with stainless steel parts in the trans and only 6 moving parts in the trans too.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Thank You
Sep 09, 2008 | Maytag Washing Machines
Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
Mar 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Two year old Maytag Fridge not cooling
pull the power plug for 15 minutes, then plug back in...same problem? tried adjusting temperature control knob (thermostat)? if yes to both questions, freon has escaped out of loop or faulty thermostat. Attempt force start of compressor with jumper clips: pull the power plug then find the two wires into motor and apply 120 VAC from jumper clips. If it spins, then faulty thermostat.
Jun 18, 2007 | Maytag MTB2656G Top Freezer Refrigerator
Maytag Atlantis MAV6000 Top Load Washer Logo
786 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
