Question about Hotpoint WMA35 Front Load Washer
How do i do a hard reset?
  • 1,894 Answers
Remove it from power plug it off from 24 hours and then use it again
Posted on Jun 09, 2008
My Hotpoint WMA35 leaks water internally into the drum when the machine is not in use ?
The inlet water solenoid valve is faulty and must be replaced. usually it's right under the top cover where the inlet hose enters the machine. An easy DIY repair but remember to disconnect the electricity and water supply first.
Mar 09, 2011 | Hotpoint WMA35 Front Load Washer
Hi, I've just done a wash on my Hotpoint WMA35 but it will not do the spin cycle. I hear the usual whirring sound as if the spin is about to start, but it doesn't. I've rearranged the load but still...
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
Feb 07, 2011 | Hotpoint WMA35 Front Load Washer
Wheres the filter on the wma35
The filter is located at the rear of the washer.
Remove lower rear cover, remove large black hose on bottom of drum.
Remove and clean plastic filter inside the hose.
Fit back and test.
Mar 24, 2010 | Hotpoint WMA35 Front Load Washer
The top off Hotpoint WMA35 washing machine?
Located at the front end of the top cover, are 2 plastic covers, prise them out with a small screw driver or something similar, and inside are 2 torx screws, get a torx screwdriver, and undo the 2 screws, if tyou don't have the correct screwdriver, you may be able to undo them with a small screwdriver.
Give the top a good hard push towards the rear, and it should come off..
Hope this helps.
Dec 28, 2009 | Hotpoint WMA35 Front Load Washer
My waterpump clicks (turning the impellor by hand )is that normal or should it turn easily .it works fine but very noisy hotpoint wma35
The clicking sound you refer to is normal, but a noisy pump indicates a worn pump, so I would advise you to replace the pump.
Also, remove the large black hose fastened to bottom of drum,and remove and clean the plastic filter inside the hose.
Hope this helps with your problem.
Please rate my solution.
Dec 23, 2009 | Hotpoint WMA35 Front Load Washer
How do i change the brushes on my wma35 hotpoint washing machine so that it'll spin?
unplug first then remove top cover motor should be there remove motor 2 bolts then u can change brushes
Jun 30, 2009 | Hotpoint WMA30 Front Load Washer
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
I have only bcold water feed but washer has hot/cold do i need 2
If it is a hot and cold fill m/c, what you need is a fitting that is referred to as a" Y" piece..To fit it, connect the straight leg of the "Y" piece to the cold supply tap, and then fit a hose to each of the two outlets, connecting each of these to the 2 inlets on the valve to the washer..
It will then fill with water, regardless of the programme you select.
You can purchase the "Y" piece connector from most hardware shops, or B&Q, and the like.
Plz rate my solution.
Jan 12, 2009 | Hotpoint WMA35 Front Load Washer
Cleaning my machine
i have a maytag washer, when i wash clothes ,it is starting to leak from the bottom.can you tell me what the problem is.
Mar 31, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint WMA35 Front Load Washer Logo
138 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
