Question about Panasonic KV S2026C Path-Through Scanner
Panasonic KV S2026C
While documents were scanning, I would get the message "unable to set extended settings:unsupported capability (V9.1924).I would have to shut the entire program down and restart the scanning process. Now the red error light stays on and I get the same message. I can't scan anything. Please help
4 Suggested Answers
namizhka
  • 148 Answers
SOURCE: KV-S2026C not scanning
LET ME ASK A FEW MORE DETAILS ABOUT THIS:
1. DID YOU GOT ANY ERROR MESSAGE ON YOUR DESKTOP OR LAPTOP?
2. WHAT OS OPERATING SYSTEM IS CURRENTLY INSTALLED AND YOUR ARE USING RIGHT NOW..?
3. HAVE YOU INSTALLED THE SCANNER DRIVER ON YOUR PC?
4. DO YOU CHECK IF ALL THE CABLE CONNECTION FROM THE SCANNER TO THE PC ARE PROPERLY HOOKED UP AND ALSO CHECK THE POWER SOURCE.?
KINDLY POST ME BACK HERE ABOUT THIS, AND SOME ADD INFO YOU INPUT WILL DO..
KEEP US UPDATED.
Posted on Oct 02, 2008
SOURCE: My panasonic kv-s2026c has a black line running
CHECK THE GLASS for a scratch.. i have one on mine from a staple sneaking through and it now puts a permanant line on all documents....OR it could be a piece of gook on the glass
Posted on Feb 17, 2011
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Posted on Jan 26, 2012
Kv-s2026c paper jam
Are you just receiving paper jam message or paper is actually jammed in the unit.Or the paper is getting jammed every-time while getting the printout.Click this link below :-----
http://technoanswers.blogspot.com/2012/01/every-question-has-answer.html
Thanks.
Jan 26, 2012 | Panasonic KV-S2026C Pass-Through Scanner
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Auto crop and Deskew ?!! everytime i try to scan it pops up with a message saying...these settings will be ignored: -autocrop -deskew we have to scan document that are really long and i cant have it...
I know this is very old and you have probable answered your own question, but in case anyone else finds this...
Search google for panasonic reference area/roller, they are two rollers inside your scanner, if they are set to white Deskew and Autocrop amongst others will be disabled, if its set to Black they become available, I spent two days trying to sort this.
Oct 19, 2011 | Panasonic KV S2026C Path-Through Scanner
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
Jan 13, 2011 | Panasonic KV S2026C Path-Through Scanner
Line in scanned document
Its dirt! It takes just one tiny speck of dirt on the lens to make a vertical line.
We have some scanner maintenance videos;you want to clean the CIS front sensor.
Regards,
MyEfact
May 12, 2010 | Panasonic KV-S2026C Pass-Through Scanner
Scann almost unreadeble, letters look like broken
You should increase resolution of you scans. By default in 300 dpi set it to higher value using scanning utility.
Sep 28, 2009 | Panasonic KV S2026C Path-Through Scanner
Yellow light is blinking and error indicates clean rollers. Rollers have been cleaned but message keeps coming back. No problems scanning.
Panasonic includes a user utility with this model. The utility can be accessed via Start>All Programs>Panasonic. In it you will find a display and reset function for the cleaning count. Sorry I don't have more specifics, its been a while since I worked on any Panasonics.
Apr 06, 2009 | Panasonic KV S2026C Path-Through Scanner
Scan only in jpg.
If you want to scan in TIFF, you need to scan in monochrome only. (B&W). Change SCanner settings.
S. Mohan, Chennai, India
Feb 05, 2009 | Panasonic KV-S2026C Pass-Through Scanner
Panasonic KV S2026C Path-Through Scanner Logo
156 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
