Question about Janome Memory Craft 9500 Computerized Sewing Machine
Janome 9500 Embroidery Issue
I was embroidering one project and completed it. Went to the next and when I pushed trace to ensure it was alined properly the machine would only go left and right not up and down. The machine made the noicse as if was going up and down but never moved. When I pushed the start button the machine never moved the all the embroidery was all in one spot. I ws prompted to lower the Dog Feeder which I did and to no avail, this was no help at all either. Any suggestions?
  • 323 Answers
This machine needs to go to the dealer for service. Check to see if it is covered under warranty.
sewman7
Posted on Jun 19, 2008
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Cheers,
Embroidery Services
San Diego, CA
May 28, 2016 | Janome Memory Craft 9000 Computerized...
Can I use Bernina Embroidery Cards with my Janome MC9500
Getting That Embroidery Design To Your Janome ...
https://tv-sewingcenter.com/janome/getting-that-embroidery-design-to-y...
Aug 21, 2010 - The designs will then be recognized by your embroidery machine, and you will spend more .... you can use either jef or jef+ for your 11000se .... like to know what brand,size and card reader to purchase for my Janome MC 9500. ...... Bernina · Elna · Embroidery · General · Janome · Necchi · Quilting · Sewing ...
Janome MC9500 100 Stitch Sewing 5.5x8" Embroidery ...
www.allbrands.com/products/8905
Janome MC9500 5.5x7.8" Embroidery .jef Format Replaces Memory Craft MC9000 ... to creative quilting and clothing construction, your sewing projects will go ... designcards) or Compact Flash Memory Cards (as used in digital cameras). ... My set screen controls for contrast, In./Cm. designation, and other customization
Which format does my machine use? - Embroidery.com
https://www.embroidery.com/help.ec?docID=225
Dec 26, 2015 | Janome Sewing Machines
My janome memory 9000 squeaks when embroidering
If it squeaks when you are embroidering and not when you are sewing, it's the belts on the embroidery unit. From use, they can become glazed, slick and then they squeak.
If it squeaks when you are doing either, it's more than likely an internal lubrication of the machine that needs to be done by a trained technician.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Janome Memory Craft 9000 Computerized...
Janome mb4 restarts in different place after stop to replace broken needle
My machine is a bit different than yours but there is a way to back up your Janome 10 stitches at a time. Here is a thread that I initiated at the janome embroidery forum that should help you. Digimad included a detailed help for me. It should direct you to get you going again. Do join the forum the gals there are generally a great bunch and very helpful.
http://content.janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=4317
Aug 19, 2012 | Janome Sewing Machines
I think it needs to be lubricated because it is very difficult to move the needle up and down. How do I do this? Janome 10000
Your Moen single-handle push-pull sink may become difficult to force down and take up if the tube within the tap has missing its oiling. Hard-water enzymes may be a aspect, but you can fresh away any remains while lubricating the tap. To make managing the tap simpler, just take apart the tap and lube the tube. Since your Moen single-handle sink has few inner areas, this is an straightforward process
<a href="http://www.digit-embroidery.com/embroidery-digitizing">Embroidery Digitizing</a>
Jul 20, 2012 | Janome Memory Craft 10000
Broken Carriage?
I do not think this is a DIY repair. That said, it seems likely gearing has been damaged. Without a workshop manual, even if you found the gear, you do not know the identification number for it. I see no authentic download of the workshop manual on the web for this Memory 9500.
I only find the Instruction manual available on the web (freely available at the Janome site). Even if you find a Janome technician on an answer site, that is not going to get you disassembling the machine, replacing the part, reassembling it, and adjusting it.
Check Janome support and see what they offer: tech advice, workshop manual for sale, and/or parts. You are likely to conclude you need to find someone at a service center.
Here are some links:
http://janome.com/en/support
http://janome.com/siteassets/support/manuals/retired/embroidery/inst-book-mc9500.pdf
Instruction Manual Janome and Newhome 9500 (hardcopy, some parts)
http://www.janomeservicevideos.com/wordpress/wp-content/uploads/2015/02/Error-Codes.pdf There is only one reference to the 9500 on the page.
Sep 03, 2017 | Janome Memory Craft 9500 Computerized...
I was using an ATA PC card with adapter and did several embroidery designs. when I went back to the machine later and tried to pull up more designs to embroider all I got was a "communication error" on...
I have had the same thing on my 11000 Janome. Asked the repair guy, but did not get an answer perfectly. It could be the mother board from what I gathered, it happens very infrequently but you loose everything and have to start over again. Very frustrating if you made any alterations to the pattern-I have learned to save everything in case it happens. Then I just start over but it is at least saved.
Oct 04, 2010 | Janome Memory Craft 9500 Computerized...
In embroidery mode I insert a card adapter into my machine and all I get is a "communication error" I have a Dynex card reader which works fine on my computer. I also have PQ1 compactFlash adapter that...
The solution was sooo easy.....one of my online embroidery groups suggested to put the card in my Janome and let the machine format it. It took about a minute and did not tell me what it was doing..and It worked! It put two folders on my card, Emb5 and ord#5, and I was to copy the jef files into the Emb5 folder, which I did and bingo! my Janome 9500 read the card and produced a screen with my jef files in it. I am a happy camper....I don't know if this works with all Janome machines but it did with mine.
Thanks for being here to help.
Pepsi lady
Jun 24, 2009 | Janome Memory Craft 9500 Computerized...
Janome Memory Craft 9500 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
