Central ac blowing hot air outside fan not moving but making a noise
I came home from a weekend away to a hot house. I have a digital thermostat and it read 90 inside! I turned it off when I realized that it was blowing hot air. This am I went outside to look at the unit and it is making a noise like it is running, but the fan is not moving. I really don't want to get ripped off. Could you please give me some advice or at least give me questions to ask a technician so I don't sound like a walking bank.
  • 3 more comments
  • Anonymous Jun 21, 2008
    We have the same problem. I turned on the central air and 2 hours of it realized it was blowing warm air. I went outside to see the fan not moving and heard a noise of something trying to run. I got the fan blades moving again but still warm air? I have someone coming out this afternoon to look at it. He said probably needs a new fan $400 part? I know nothing of A/C stuff & it is Sat & it is over 100* here in the desert. I hope I don't get the run around & that someone is honest.
  • angela1207 Jul 27, 2008
    My fan on the outside unit comes on for a few minutes then stops running and starts blowing hot air..it has been cheched for freon and filters have been changed as well as the thermastat. need help ...
  • wendypol Aug 07, 2008
    outside unit fan not blowing sounds like it wants to come on but doesnt move and unit feels hot. Air is blowing inside but its warm air, no cool air at all. Can you help?
  • Anonymous Apr 05, 2009
    I have a digital thermometer. It reads 76 degrees. I put it on 69 degrees and its not blowing cold air or decreasing the temp inside. I got outside to my unit out there and the fan isnt moving and there is no noise. Its like the thermometer and unit inside is doing everything fine but the unit outside is doing nothign and not making any moise whatsoever. It was fine yesterday evening. This I noticed this evening. Why would my unit outside not be maiking any noise like tis doign nothing and the fan isnt moving? This system itself isnt old. Its a fairly new system.
  • Anonymous Apr 18, 2009
    My AC unit is blowing hot air. I checked the compressor outside and the fan is not blowing. I hear a noise though. I don't want this to break the bank, what cuold be the problem?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Posted on Jun 09, 2008
When I turn my AC unit on the outside fan comes on and stays running for about 45 minutes then fan stops running then it blows HOT air need help...
Posted on Jul 27, 2008
Ny ac unit is still blowing i have the temp at 78 and it 78 and its been run for 1 hour straight and its still at 78
Posted on Aug 24, 2010
    Problem Solver:
  • 10 Answers
The most common cause of this issue would be a capaciter failure. I have 3 ac units and had an AC company come out to fix a similar issue and it cost me nearly three hundred bucks! I watched the tech fix the unit and figured I could do it myself with some guidance the next time. This year when another one of my capaciters went out I found a repair kit online with pictured instructions in a guide and phone/email support and saved over two hundred bucks on the capaciter replacement this time! The site I bought the repair kit from is hvacrepairkits.com - good luck!
Posted on Aug 14, 2011
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
2003 kia optima heater wont blow hot air
Hi James,
First, I guess you realize that the heater is part of your engine cooling system. Then it also has its own parts inside the vehicle that have absolutely nothing to do with the engine cooling system.
The trick to getting your heater working is to first determine which part of the heater system has the problem.
First, you need to verify proper engine cooling system operation. There is more to this than just replacing a thermostat. If you have a problem like a blown head gasket, you r heater will not work. What SHOULD be done is to operate the engine while watching the computer data for the engine coolant temperature sensor (ECT). Doing This, you can verify that the engine is warming up to operating temperature. You can also verify that the thermostat is opening at the correct temperature. Then take an infrared thermometer and take a manual reading from the engine near the temperature sensor. The reading you get from the thermometer should be within about 5 degrees of the reading that the computer is getting from the ECT. The engine cooling fans should come on between 220 and 228 Deg. F. When they do come on, the air that is blowing through the radiator should be HOT. If it is not, this is an indication that the radiator is stopped up, the water pump is not pumping correctly, or there is a blown head gasket that is filling your cooling system with combustion gasses. This can be done with just the thermometer, but it is best to also verify the ECT computer data.
If all of this is working properly, then it is time to look INSIDE the car for the problem. The blend-air door in your A/C-heater housing may not be working. When you switch the temperature control inside the car, you should be able to HEAR a change in the air flow. This applies to ALL vehicles, whether they are equipped with cable, vacuum, or electronically controlled blend air doors. If you cannot hear a difference in the sound of the air moving through the A/C-Heater housing, then chances are pretty good that the problem is with your blend-air door. If this seems to be the problem, let me know and I can give you further instructions on how to check this and/or repair the problem.
P.S. Just thought I'd mention that a pretty good infrared thermometer can be purchased at any parts store for around $40.....This is a very good investment because you can use it for many other things and is a lot cheaper than an hour of diagnostic time at most repair shops.
Dec 05, 2011 | 2003 Kia Optima
When it is hot outside 80 to 90 i take the canon from inside the house and go outside the camera turn it on and nothing, i have changed battery, lens, and sd card. come back inside cool the camera off ,...
There is a moisture sensor in those cameras, it is probably not so much the temp but possibly condensation. I would contact Canon, because that should not be happening.
Jun 14, 2010 | Canon Digital Rebel XSi Digital Camera
Wont heat up
if u used self clean and now u have problems more than likely u blow out the thermosat on the backside of the unit, this is kinda common with these it gets so hot inside that these thermostats blow..... to check it remove side trim pieces usually screws...turn power of at breaker to unit first.... then remove moutning screws that hold it into cabinent..... get two people and remove wall oven,, then remove back panel to get acess to thermostat... test it with a meter for continuity if it reads somethin its good or closed circuit, if it reads nothin it is an open circuit and a bad part,,,,,,if that checks out okay then ur control board may be effective... hopefuully this helps most thermostats are usually 40-90 dollars.. let me know
Apr 10, 2010 | Whirlpool GBS307PR Electric Single Oven
Hot water will only work if the heating is on?
I take it you are in a new (to you) house. Sounds like you have "tankless" hot water, which means the same burner that heats the house also heats the hot water for your sinks and shower. So as a minimum, yes the power to the furnace must be on, but that doesn't mean you have to heat the house. You can turn down the thermostat and leave the power to the furnace "on". To save a few bucks, turn it off when you go away for the weekend, or even for the day, the response time to heat it up is usually pretty fast.
Mar 23, 2010 | Water Heaters
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
11,360 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
