Question about Fedders A6P09S2A Air Conditioner
Air conditioner temperature is set at say 70 and suddenly the unit goes up to 88 by itself
How do you make this unit cooler. I set it for 68 and the temperature stays at 80
Posted on Jul 21, 2008
    Problem Solver:
  • 7 Answers
Maybe you set the tempture to 70 and when the unit is runnung it sinces the room tempture.
Posted on Jun 15, 2008
My panasonic air conditioner does not turn off when cooling
At what temperature is the thermostat?
The temperature should never be lower than 70?F (21?C) for the unit to operate properly. If your temperature setting is above 70?F, then your unit might have a problem with the temperature sensor that controls the "on/off" cycle on your unit. For that you will need a professional certified HVAC tech to inspect it.
Most people think that lowering the temperature to the minimum will cool the room faster, but that is not the case. Since HVAC units move the air at a specific rate, it can only transfer the temperature, thus cooling/heating the air, within those parameters. That's what the calculation for the BTU is for. Normally cooling/heating the room to the desired temperature should take about 1 hour, but some new inverter units can do it in only 30 minutes or so. Lowering the temperature constantly or even keeping it at the lowest setting may cause premature failure of the unit.
Aug 04, 2014 | Panasonic 36PEF1U6 31,200 BTU Single Zone...
Air conditioner will not stay on a selected temperature in cool mode for more than 3 seconds. For example, you can change the temperature to 70 degrees and it will blink for 3 seconds and move back to 88...
Don't you just hate electronics? The control might be sensing a bad thermostat. Especially considering that the manual says that the max temp is 86 (not 88).
Jun 03, 2011 | LG LP0711WNR Portable Air Conditioner
After five minutes ac is starts tripping again it starts for some time and stops.even we set it at 16deg temprature
For beginners, 16 degrees cannot possibly be the temperature you are setting your A/C unit to... and anything below 70 degrees F you are risking freezing up your unit! Sounds like it might be a good time to invest in a new unit?
Jul 10, 2010 | Whirlpool Electronic Window Air...
This unit has a manual thermostat. Is there a way
60 IS A DREAM TEMP MOST UNITS WILL NEVER REACH THESE TEMPS. THERE NOT MADE TO. AT 60 YOU LOWER THE HEAT ABSORPTION INSIDE AND OUTSIDE AND WITHOUT HEAT IT BEGINS TO ICE UP WHEN IT IS 70 INSIDE AND 70 OUT SIDE YOU WILL ICE UP 75 IS GOOD SETTING. IF YOUR TSTAT HAS A HOLD BUTTON SET TEMP AND PRESS HOLD THAT MY HELP
Apr 20, 2010 | LG LXA1030ACL Air Conditioner
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Evaporater freezes up after running for aa short while
HELLO THERE:
When you set the temperature settings down around 64 or lower the unit will freeze up so i recommend to keep it at around 68 or 70 ok this will keep it from freezing also make sure that the unit is free of any obstructions so the air can freely get to the unit ok?
best regards michael
Aug 27, 2009 | Whirlpool ACM184XP Air Conditioner
Air conditioner turned itself on to 22 degrees.
If it got to 22 degrees the Ac unit should have self destructed. What brand and model is that unit?
I think I would love to have one here in Georgia.
Aug 21, 2009 | Royal Sovereign ARP-4012 Portable Air...
AC changes temperature by itself!
If it's not some sort of built in economizing feature, someone else isn't getting up and changing the temperature while you are asleep and the air conditioner fairy is playing tricks, then the control PCB is in need of repair and will have to be repaired through a sears authorized repair center.
I am a bit surprised that it will allow you to set the temperature to a low 70 degrees as this is pushing the limits of an air conditioner. They tend to freeze the coils at around that temperature.
Jun 07, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Fedders A6P09S2A Air Conditioner Logo
111 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Tony Pez
Level 1 Expert
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
