Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Fax machine problem brother 1820c
My paper is not sending properly, it's twisting and turning
The ADF rollers may be dirty or may even be damaged. To determine this, 1. Open the transmit door. 2. take a look at the condition and placement of rollers and sensor actuators.3. Using a lintless rag and 99% Isoprpynol, clean the rollers thoroughly. 4. Clean the scanner glass and also the white strip on the transmit door opposite the glass. 5. Do not forget to examine the final roller (paper out roller) This may be damaged or the gear or even the plastic clips that hold this down may be broken. finally make sure that the transmit door can be snapped shut properly.
Posted on Jun 10, 2008
HOW CAN I STOP THE MACHINE FROM PRINTING AN ERROR REPORT AND WASTING A PAGE OF RIBBON
The brother fax machine will always print out a transmission report when there is a failure to send a fax.
There is no way to turn this feature off.
The closest option to this is turning transmission reports off, but this will still print out a message when the fax does not go through properly.
Mar 25, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Want to change it to black and white printing only.
A manual for your fax is available here, and will show you how to set your fax to monochrome mode.
Apr 14, 2008 | Brother PPF-1820C Plain Paper Inkjet Fax
Paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 05, 2010 | Brother IntelliFAX 1820C Plain Paper...
Error 41 is showing up on the screen. says to contact brother. It's a intellifax 1820c.
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Apr 21, 2009 | Brother IntelliFAX 1820C Plain Paper...
Pages aren't being sent properly
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Find reset button on brother 1820c color fax copier
Reset button? What does the button reset?
The only way I know to reset Brother Faxes is with software codes.
Nov 22, 2008 | Brother Office Equipment & Supplies
Problem with the F/T setting.
Try this address for the manual download.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=17b84254e3dbb23957d540855b6268ee&q=Brother+FAX-1820C
Nov 13, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother Intelifax 1820c problem
that is a printhead error. call brother and see if its under warranty by giving them the serial number. if its not, the last i knew, the printhead w/ cartridges was about $100.00. hth, ray
May 31, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
