Question about Kenwood KDC -X815
Kenwood head unit CD and AUX sound not working
I have a Kenwood KDC x815 head unit. I just replaced the ribbon cable from the circuit board to the faceplate and when i put the unit into my vehicle the tuner works fine but I cant get any sound out of the CD or the AUX. The CD is playing the CD be cause the display shows the time of the cd moving and the level lights are moving. I can also change tracks and I can hear the mechinism moving inside. I also have an MP3 player hooked up through the changer input cable that also is working but not getting any sound out. I know the head unit is getting the signal from the MP3 player because the level meters work and when I pause the MP3 player, the level meters stop. Any suggestions? Thanks.
  • Anonymous Apr 18, 2009
    Where did you get the ribbon cable from? I need to replace mine.
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Posted on Jun 11, 2008
I plugged an iPhone USB cable into my Kenwood KDC-BT652U head unit and heard a pop through the speakers in my truck. I lost all power to the head unit and now it won't turn on at all. Any ideas????
Check the fuses on the head unit. There should be one that you can check, it might be that the cable pulled too much current. USB is not a high current provider.
Jan 30, 2014 | Kenwood Kdc-bt652u Cd/mp3 Receiver...
Radio does not turn on, and can not eject cd.
HAVE YOU REPLACED UNIT? IF YOU HAVE THEN IT COULD BE THE SWITCHED / CONSTENT FEED BEING AROUND THE WRONG WAY, YOU CAN TEST TO SEE IF YOU HAVE A CONSTENT FEED WITH IGNITION OFF ON ONE OF THESE, AND A FEED ON THE OTHER YOU TURN IGNITION ON, THE THESE ARE NORMALLY RED AND YELLOW SWAP THEM ROUND, GROUND/EARTH IS BLACK, FUSE N HEAD UNIT NORMALLY BEHIND THE PLUG THAT FITS IN THE HEAD UNIT
Dec 06, 2009 | Kenwood KDC -X815
I can't play my iphone on my kenwood KDC-MP435U
Jennifer, I have the same issue. the problem is that the 2007+ generations of Kenwood receivers are not compatible with the iPhone. You will need to get a 2009+ series in order to use your iPhone with the head unit. I had the same issue with the Kenwood KDC-MP435U in my mustang. I am going to get a newer head unit that supports the iPhone. You cannot do it with the MP435U.
Nov 25, 2009 | Kenwood KDC-MP435U CD Player
Whats the code to unlock my kenwood kdc 7011 cd player ?
acan't get the code for my kenwood KDC-X815 thank you
"Alfaro"
Sep 16, 2009 | Kenwood KDC-MP528 CD Player
Ipos nano 3
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
Sep 02, 2008 | Kenwood KDC-135 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
Faceplate won't close
Alot, of the radios have a common problem with the connection from the radio's2.gif detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD2.gif and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, the display partially turning on and off, and the face to act peculiar and flip down halfway. In addition, sometimes the face open and close switches go bad, but I've never had to replace them yet. .
Dec 15, 2007 | Kenwood KDC -X815
Kenwood KDC-519 CD Player
Check ribbon cable from main board to face for breaks in the lines. Replace ribbon cable if bad.
Aug 01, 2007 | Kenwood KDC-519 CD Player
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Kenwood KDC -X815 Logo
711 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
